[mapserver-users] Rendering line crossing iteslf
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 11 10:06:49 EDT 2011
Oops, right. brain not in gear yet :)
On 5/11/2011 10:04 AM, thomas bonfort wrote:
> ---------- Forwarded message ----------
> From: thomas bonfort<thomas.bonfort at gmail.com>
> Date: Wed, May 11, 2011 at 16:03
> Subject: Re: SV: [mapserver-users] Rendering line crossing iteslf
> To: Stephen Woodbridge<woodbri at swoodbridge.com>
> Steve,
> That isn't the case. The first style of all the features are rendered
> in a first phase, and the following ones are rendered in a second
> phase, so the order is
> feature1->style1
> feature2->style1
> featuren->style1
> feature1->style2
> featuren->style2
> feature1->stylem
> featuren->stylem
> without that, you'd get artifacts on road intersections.
> thomas
> On Wed, May 11, 2011 at 15:47, Stephen Woodbridge
> <woodbri at swoodbridge.com>  wrote:
>> Niels-Peter,
>> I believe that you will need to split the line at the intersection into
>> multiple lines to get the display that you want. Because you line just
>> crosses itself there is no intersection there. If you split the line into
>> multiple segments that there will be an intersection and mapserver should
>> render it is desired.
>> -Steve W
>> On 5/11/2011 8:18 AM, Niels-Peter Jensen wrote:
>>> Hi Thomas
>>> The bridge was used as an anology. In fact, the line feature is a bus
>>> route
>>> that crosses itself, and we just want to show where the route passes
>>> through
>>> an intersection.
>>> Niels-Peter
>>> -----Oprindelig meddelelse-----
>>> Fra: thomas bonfort [mailto:thomas.bonfort at gmail.com]
>>> Sendt: 11. maj 2011 13:56
>>> Til: Niels-Peter Jensen
>>> Emne: Re: [mapserver-users] Rendering line crossing iteslf
>>> On Wed, May 11, 2011 at 13:51, Niels-Peter Jensen<npj at i-gis.dk>    wrote:
>>>> Hi Thomas
>>>> Thanks for the quick answer.
>>>> We cannot make the style work in the mapfile and have to place it in
>>>> the symbol file. By the way, we are using Mapserver 5.4.2.
>>>> But anyway, I don't think it solves our problem.
>>>> We don't have any "bridge" in our line data, it is just a single line
>>>> feature that crosses itself.
>>> then how can you distinguish the case of the bridge with the case of the
>>> intersection ? applying the solution I proposed on all lines will give
>>> incorrect cases everywhere you don't have a bridge, so it would not be a
>>> possible solution.
>>> thomas
>>>> Regards
>>>> Niels-Peter
>>>> Sendt: 11. maj 2011 12:14
>>>> Cc: mapserver-users at lists.osgeo.org
>>>> An undocumented and "not guaranteed to work in future versions" is to
>>>> trick mapserver in not drawing the cached base style for bridge lines.
>>>> As you are avoiding the line caching mechanism, you have to tweak the
>>>> linecaps for the base style.
>>>> CLASS
>>>>    EXPRESSION ([bridge]=1)
>>>>    STYLE
>>>>    END
>>>>    STYLE
>>>>       color black
>>>>       width 5
>>>>       linecap butt
>>>>    END
>>>>    STYLE
>>>>       color yellow
>>>>       width 3
>>>>       linecap round
>>>>    END
>>>>    STYLE
>>>>       color black
>>>>       width 1
>>>>    END
>>>> END
>>>> I haven't tested this recently, so please keep in touch if this solves
>>>> your problem or not.
>>>> regards,
>>>> thomas
>>>> On Wed, May 11, 2011 at 11:40, Niels-Peter Jensen<npj at i-gis.dk>
>>>> wrote:
>>>>> Hi users
>>>>> We have a problem in rendering a route based on a line feature.
>>>>> When we use the common way to do that, by using two styles, with a
>>>>> thick black line that defines an outline, and a thinner defying the
>>>>> road center, we will not get the desired result.
>>>>> But I want to show where routes cross ("bridge" intersection), and
>>>>> not as a "normal" intersection, see the attached examples.
>>>>> As there is no outline definition on linefeatures I can't se how that
>>>>> can be done in a simple way.
>>>>> Niels-Peter
>>>>> I-GIS
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
