[mapserver-users] Layer rendering performance problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu May 12 02:52:30 EDT 2011
For clarification, it used to be rather a long time ago that the index file (.qix) was not utilised even it was present in the data folder if the LAYER DATA was given as
DATA "C:\Data\WMS_DATA.shp"
Index was used only if the LAYER DATA was like
DATA "C:\Data\WMS_DATA"
However, this in old knowledge and both WMS_DATA.shp and WMS_DATA are utilising the index nowadays.
Gdal is using the same .qix index file system and therefore also QGIS. There is more info about gdal shapefile spatial index in http://www.gdal.org/ogr/drv_shapefile.html
The page tells also that native ESRI spatial index files (.sbn/ .sbx) are not supported.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Ben Madin
Lähetetty: 12. toukokuuta 2011 4:00
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] Layer rendering performance problem
I'm not sure whether it is still the case, but it used also to be that if you wanted to use the index, you need to name the shapefile without the .shp extension. If you used the .shp extension it wouldn't use the .qix index.
So maybe this is a question - Is that still the case?
On a similar note, does anyone know ... is the index created with shptree the same as the one created by QGIS (also a .qix file)?
cheers
Ben
On 12/05/2011, at 10:45 AM, mapserver-users-request at lists.osgeo.org wrote:
From: Stephen Woodbridge <woodbri at swoodbridge.com>
Date: 11 May 2011 11:53:34 PM AWST
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Layer rendering performance problem
look at the mapserver utilities:
shptree myshapefile
This creates a spatial index (*.qix) and you should create one for every shapefile you are using.
On Linux this will do the trick:
find /path/data -name \*.shp -exec shptree {} \;
If the .qix file is missing on every draw mapserver must create one on the fly in memory and the it throws it away.
-Steve W
On 5/11/2011 11:47 AM, Jon-Paul Dobson wrote:
Hi Jukka,
Thanks for getting back to me so quickly. No I haven't tried this. How
is this done and what is the benefit? Aren't Shape files already indexed?
Regards,
Jon-Paul.
On Wed, May 11, 2011 at 4:41 PM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi <mailto:Jukka.Rahkonen at mmmtike.fi>> wrote:
No answers but a question back. Have you created spatial index
(.qix) for your shapefiles with shptree?
-Jukka Rahkonen-
> Hi,
> Whenever I display a layer based on a Shape file I notice that
the Shape
file is accessed constantly. This makes rendering extremely slow when
compared to, for example, ESRI ArcIMS which appears to cache the
Shape file.
Is there an equivalent caching mechanism for Map Server? ArcIMS seems to
render an order of magnitude faster when the number of symbols runs
into the
1000s
> Similarly, whenever I display layer symbols using a truetype font
I notice
that the .ttf file is accessed for every symbol. This makes rendering
appallingly slow. Is there also any caching mechanism to prevent this?
> Any insight anyone can give would be much appreciated.
Best regards,
Jon-Paul.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110512/52321c84/attachment.html
