[mapserver-users] Question on rfc 86
Josh Hevenor
jhevenor at rogers.com
Sat May 14 22:01:55 EDT 2011
Thanks Tamas,
The legend is custom build by mapscript and it's a feature of the app
that it shows the out of scale layers. I could customize it to group
layers that are essentially the same thing if there was a need for it,
but I figured I'd see if this new feature would do that for me for free
when I upgrade to ms6.
If the UNION layer respected the source layers {min|max}scaledenom
settings that would work for me. Are there any other ways to have a
single layer provide more detail when zoomed in? Just curious.
Josh
On 5/14/2011 3:21 PM, Tamas Szekeres wrote:
> Josh,
> The union layer always retrieve all features from the source layers
> regardless of their visibility. This is because the source layers are
> hidden in most cases (STATUS OFF) to avoid the duplication of the
> features drawn.
> However the desired scale range (MINSCALEDENOM, MAXSCALEDENOM) could
> indeed be taken into account when accessing the source layers, by
> using a minor change.
> BTW: How the legend is drawn in your case? As far as I know mapserver
> draws only the layers in the scale range by default.
> Best regards,
> Tamas
> 2011/5/14 Josh Hevenor <jhevenor at rogers.com <mailto:jhevenor at rogers.com>>
> This may or may not be relevant but reading RFC 68 got me wondering.
> I have an application that has shape file data for lakes. There are
> different shapefiles for data with higher accuracy that are used with
> scale ranges so that only one is drawn at a time. Specifically
> something like lakes_1_1m, lakes_1_250k, lakes_1_50k.
> I'm really looking for a way to show one LAKES layer in the
> application
> legend instead of 3 layers, two of which are always out of scale.
> Can or
> should I use a UNION layer to connect these layers? What other
> approach
> should I consider?
> Thanks for the advice,
> Josh
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 8.5.449 / Virus Database: 271.1.1/3637 - Release Date: 05/14/11 06:34:00
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110514/57c62962/attachment.html
