[mapserver-users] Question on rfc 86
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sun May 15 06:10:06 EDT 2011
Have you tried GROUP?
LAYER
GROUP "group_layer"
NAME "level_1"
STATUS ON
TILEINDEX "d:/data/...."
MAXSCALEDENOM 14000
LAYER
GROUP "group_layer"
NAME "level_2"
STATUS ON
TILEINDEX "d:/data/....."
MINSCALEDENOM 14000
MAXSCALEDENOM 100000
WMS clients will show all the layers in a tree with level_1 and level_2 as members of group_layer. However, all your users need to do is to add group_layer into their WMS client.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Josh Hevenor
Lähetetty: 15. toukokuuta 2011 5:02
Vastaanottaja: Tamas Szekeres
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] Question on rfc 86
Thanks Tamas,
The legend is custom build by mapscript and it's a feature of the app that it shows the out of scale layers. I could customize it to group layers that are essentially the same thing if there was a need for it, but I figured I'd see if this new feature would do that for me for free when I upgrade to ms6.
If the UNION layer respected the source layers {min|max}scaledenom settings that would work for me. Are there any other ways to have a single layer provide more detail when zoomed in? Just curious.
Josh
On 5/14/2011 3:21 PM, Tamas Szekeres wrote:
Josh,
The union layer always retrieve all features from the source layers regardless of their visibility. This is because the source layers are hidden in most cases (STATUS OFF) to avoid the duplication of the features drawn.
However the desired scale range (MINSCALEDENOM, MAXSCALEDENOM) could indeed be taken into account when accessing the source layers, by using a minor change.
BTW: How the legend is drawn in your case? As far as I know mapserver draws only the layers in the scale range by default.
Best regards,
Tamas
2011/5/14 Josh Hevenor <jhevenor at rogers.com>
This may or may not be relevant but reading RFC 68 got me wondering.
I have an application that has shape file data for lakes. There are
different shapefiles for data with higher accuracy that are used with
scale ranges so that only one is drawn at a time. Specifically
something like lakes_1_1m, lakes_1_250k, lakes_1_50k.
I'm really looking for a way to show one LAKES layer in the application
legend instead of 3 layers, two of which are always out of scale. Can or
should I use a UNION layer to connect these layers? What other approach
should I consider?
Thanks for the advice,
Josh
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3637 - Release Date: 05/14/11 06:34:00
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110515/b984d99a/attachment-0001.html
