[mapserver-users] Question on rfc 86
Richard Greenwood richard.greenwood at gmail.com
Sun May 15 15:49:44 EDT 2011
As Jukka suggests, use GROUP, but only provide a NAME for the one
class that you want to have displayed in your legend.
HTH,
Rich
On Sun, May 15, 2011 at 4:10 AM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> Have you tried GROUP?
> LAYER
>       GROUP "group_layer"
>       NAME "level_1"
>       STATUS ON
>       TILEINDEX "d:/data/...."
>       MAXSCALEDENOM 14000
>   LAYER
>         GROUP "group_layer"
>         NAME "level_2"
>         STATUS ON
>         TILEINDEX "d:/data/....."
>         MINSCALEDENOM 14000
>         MAXSCALEDENOM 100000
> WMS clients will show all the layers in a tree with level_1 and level_2 as
> members of group_layer.  However, all your users need to do is to add
> group_layer into their WMS client.
> -Jukka Rahkonen-
> ________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Josh Hevenor
> Lähetetty: 15. toukokuuta 2011 5:02
> Vastaanottaja: Tamas Szekeres
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Question on rfc 86
> Thanks Tamas,
> The legend is custom build by mapscript and it's a feature of the app that
> it shows the out of scale layers. I could customize it to group layers that
> are essentially the same thing if there was a need for it, but I figured I'd
> see if this new feature would do that for me for free when I upgrade to ms6.
> If the UNION layer respected the source layers {min|max}scaledenom settings
> that would work for me. Are there any other ways to have a single layer
> provide more detail when zoomed in? Just curious.
> Josh
> On 5/14/2011 3:21 PM, Tamas Szekeres wrote:
> Josh,
> The union layer always retrieve all features from the source layers
> regardless of their visibility. This is because the source layers are hidden
> in most cases (STATUS OFF) to avoid the duplication of the features drawn.
> However the desired scale range (MINSCALEDENOM, MAXSCALEDENOM) could indeed
> be taken into account when accessing the source layers, by using a minor
> change.
> BTW: How the legend is drawn in your case? As far as I know mapserver draws
> only the layers in the scale range by default.
> Best regards,
> Tamas
> 2011/5/14 Josh Hevenor <jhevenor at rogers.com>
>> This may or may not be relevant but reading RFC 68 got me wondering.
>> I have an application that has shape file data for lakes. There are
>> different shapefiles for data with higher accuracy that are used with
>> scale ranges so that only one is drawn at a time.  Specifically
>> something like lakes_1_1m, lakes_1_250k, lakes_1_50k.
>> I'm really looking for a way to show one LAKES layer in the application
>> legend instead of 3 layers, two of which are always out of scale. Can or
>> should I use a UNION layer to connect these layers? What other approach
>> should I consider?
>> Thanks for the advice,
>> Josh
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 8.5.449 / Virus Database: 271.1.1/3637 - Release Date: 05/14/11
> 06:34:00
Richard Greenwood
www.greenwoodmap.com
