[mapserver-users] Union Layers and GetLegendGraphic
Tamas Szekeres
szekerest at gmail.com
Thu May 19 04:12:12 EDT 2011
Keith,
The idea looks promising. Which source layer should be used to copy the
styles?
In case if the source layer contains multiple classes (with expressions,
classitem etc.), the actual feature may be required to select the class to
be used.
Best regards,
Tamas
2011/5/19 Keith Moss <Keith.Moss at landgate.wa.gov.au>
> Hi all,
> Just noticed an issue with the new 'UNION' layer type in MapServer 6.
> With 'STYLEITEM AUTO' set the styles are inherited for GetMap requests but,
> it seems, not for GetLegendGraphic requests. Giving the UNION layer a copy
> of the styles for the source layers works, but obviously this is exactly
> ideal. Just wondering if this is on anyone's "to implement" list?
> cheers
> __________________________________
> Keith Moss
> Satellite Remote Sensing Services
> Operations
> Landgate
> 65 Brockway Road, FLOREAT WA 6014
> PO Box 741 Wembley WA 6913
> Ph. (08) 9387 0332 | Fx. (08) 9383 7142
> keith.moss at landgate.wa.gov.au
> www.landgate.wa.gov.au
> This e-mail and any files transmitted with it are intended only for the use
> of the addressee(s). It may contain information that is confidential and
> privileged, in which case neither is intended to be waived or lost by
> mistaken delivery to you. If you are not an intended recipient, any use,
> interference with, disclosure, distribution or copying of this material is
> unauthorised and prohibited. If you receive this e-mail in error, please
> notify the sender by return e-mail and delete the message and any
> attachments from your system. Unless specifically indicated, this e-mail
> does not constitute formal advice or commitment by the sender or the Western
> Australian Land Information Authority (Landgate). Information in this
> message not relating to the official business of Landgate shall be
> understood as neither given nor endorsed by it. It is your responsibility to
> check any attachments for viruses and defects before opening or sending them
> on. Landgate’s liability is limited to re-supplying affected attachments.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110519/0f464d1f/attachment.html
