[mapserver-users] Union Layers and GetLegendGraphic
Keith Moss
Keith.Moss at landgate.wa.gov.au
Thu May 19 23:44:23 EDT 2011
Hi Tamas,
The notion we had was that a GetLegendGraphic on a union layer would just work in the same way as a GetLegendGraphic on a layer group does at the moment. i.e. Displays all of the classes for all of the source layers.
cheers
__________________________________
Keith Moss
Satellite Remote Sensing Services
Operations
Landgate
65 Brockway Road, FLOREAT WA 6014
PO Box 741 Wembley WA 6913
Ph. (08) 9387 0332 | Fx. (08) 9383 7142
keith.moss at landgate.wa.gov.au <mailto:keith.moss at landgate.wa.gov.au>
www.landgate.wa.gov.au <http://www.landgate.wa.gov.au/>
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Thu 19/05/2011 16:12
To: Keith Moss
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Union Layers and GetLegendGraphic
Keith,
The idea looks promising. Which source layer should be used to copy the styles?
In case if the source layer contains multiple classes (with expressions, classitem etc.), the actual feature may be required to select the class to be used.
Best regards,
Tamas
2011/5/19 Keith Moss <Keith.Moss at landgate.wa.gov.au>
Hi all,
Just noticed an issue with the new 'UNION' layer type in MapServer 6.
With 'STYLEITEM AUTO' set the styles are inherited for GetMap requests but, it seems, not for GetLegendGraphic requests. Giving the UNION layer a copy of the styles for the source layers works, but obviously this is exactly ideal. Just wondering if this is on anyone's "to implement" list?
cheers
Keith Moss
Operations
Landgate
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged, in which case neither is intended to be waived or lost by mistaken delivery to you. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this e-mail in error, please notify the sender by return e-mail and delete the message and any attachments from your system. Unless specifically indicated, this e-mail does not constitute formal advice or commitment by the sender or the Western Australian Land Information Authority (Landgate). Information in this message not relating to the official business of Landgate shall be understood as neither given nor endorsed by it. It is your responsibility to check any attachments for viruses and defects before opening or sending them on. Landgate's liability is limited to re-supplying affected attachments.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110520/31f6adc2/attachment-0001.html
