[mapserver-users] confused about mapscript java configuration
ahmet temiz
ahmettemiz88 at gmail.com
Fri May 20 04:49:24 EDT 2011
Thank you Umberto ,
I did.
It constructed libmapscript.so, and mapscript.jar.
" make test" passes.
But, "make threadtests" gave
orkun at orkun-HP:~/data/mapserver-6.0.0/mapscript/java$ make threadtests
javac -cp ./mapscript.jar -d tests/threadtest/ tests/threadtest/*.java
tests/threadtest/MapThread.java:60: cannot find symbol
symbol : method getFeature(int,int)
shapeObj shape=layer.getFeature(0,-1);
1 error
make: *** [threadtests] Error 1
how can I solve this problem ?
regards
20 Mayıs 2011 10:15 tarihinde Umberto Nicoletti
<umberto.nicoletti at gmail.com> yazdı:
> Ahmet,
> you gave the wrong param to with-java-include-os-name and usually it is not
> necessary to specify anything as it will correctly guess from the
> environment.
> Try this:
> set JAVA_HOME to point to the jdk (NOTE: a full JDK is required, JRE is NOT
> enough)
> run ./configure (leave with-java-include-os-name out for now)
> make
> cd mapscript/java
> make clean
> make
> HTH,
> Umberto
> 2011/5/19 ahmet temiz <ahmettemiz88 at gmail.com>
>> hello
>> I think I am confused about mapscript java configuration
>> I added my configuration file
>> --with-java-include-os-name=$JAVA_HOME/include
>> But It still cannot find "jni.h"
>> I checked $JAVA_HOME:
>> orkun at orkun-HP:~$ ls $JAVA_HOME/include/
>> classfile_constants.h jawt.h jdwpTransport.h jni.h jvmti.h linux
>> // jni.h seems to exist.
>> what might have caused the problem ?
>> regards
>> Ahmet Temiz
>> Jeoloji Müh.
>> Afet ve Acil Durum Yönetimi Başkanlığı
>> Planlama ve Zarar Azaltma Dairesi Başkanlığı
>> Bilgi ve CBS grubu
>> Eskişehir Yolu 10. km.
>> Lodumlu / Ankara
>> Tel : 0 312 2872680 / 1535
>> ________________________
>> Ahmet Temiz
>> Geological Eng.
>> Information Systems - GIS Group
>> Disaster and Emergency Management
>> of Presidency
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Ahmet Temiz
Jeoloji Müh.
Bilgi ve CBS grubu
Lodumlu / Ankara
Ahmet Temiz
Geological Eng.
of Presidency
