[mapserver-users] confused about mapscript java configuration
Umberto Nicoletti
umberto.nicoletti at gmail.com
Fri May 20 05:42:58 EDT 2011
good catch, that's probably because of some of the recent changes in the
mapserver codebase.
please open a ticket and address it to me, i'll fix it asap.
BR,
Umberto
2011/5/20 ahmet temiz <ahmettemiz88 at gmail.com>
> Thank you Umberto ,
> I did.
> It constructed libmapscript.so, and mapscript.jar.
> " make test" passes.
> But, "make threadtests" gave
> orkun at orkun-HP:~/data/mapserver-6.0.0/mapscript/java$ make threadtests
> javac -cp ./mapscript.jar -d tests/threadtest/ tests/threadtest/*.java
> tests/threadtest/MapThread.java:60: cannot find symbol
> symbol : method getFeature(int,int)
> location: class edu.umn.gis.mapscript.layerObj
> shapeObj shape=layer.getFeature(0,-1);
> 1 error
> make: *** [threadtests] Error 1
> how can I solve this problem ?
> regards
> 20 Mayıs 2011 10:15 tarihinde Umberto Nicoletti
> <umberto.nicoletti at gmail.com> yazdı:
> > Ahmet,
> > you gave the wrong param to with-java-include-os-name and usually it is
> not
> > necessary to specify anything as it will correctly guess from the
> > environment.
> > Try this:
> > set JAVA_HOME to point to the jdk (NOTE: a full JDK is required, JRE is
> NOT
> > enough)
> > run ./configure (leave with-java-include-os-name out for now)
> > make
> > cd mapscript/java
> > make clean
> > make
> > HTH,
> > Umberto
> > 2011/5/19 ahmet temiz <ahmettemiz88 at gmail.com>
> >> hello
> >> I think I am confused about mapscript java configuration
> >> I added my configuration file
> >> --with-java-include-os-name=$JAVA_HOME/include
> >> But It still cannot find "jni.h"
> >> I checked $JAVA_HOME:
> >> orkun at orkun-HP:~$ ls $JAVA_HOME/include/
> >> classfile_constants.h jawt.h jdwpTransport.h jni.h jvmti.h linux
> >> // jni.h seems to exist.
> >> what might have caused the problem ?
> >> regards
> >> Ahmet Temiz
> >> Jeoloji Müh.
> >> Afet ve Acil Durum Yönetimi Başkanlığı
> >> Planlama ve Zarar Azaltma Dairesi Başkanlığı
> >> Bilgi ve CBS grubu
> >> Eskişehir Yolu 10. km.
> >> Lodumlu / Ankara
> >> Tel : 0 312 2872680 / 1535
> >> ________________________
> >> Ahmet Temiz
> >> Geological Eng.
> >> Information Systems - GIS Group
> >> Disaster and Emergency Management
> >> of Presidency
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Ahmet Temiz
> Jeoloji Müh.
> Bilgi ve CBS grubu
> Lodumlu / Ankara
> Ahmet Temiz
> Geological Eng.
> of Presidency
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110520/42a78fb9/attachment-0001.html
