[mapserver-users] QuadTree Index problem
Forest
forest21000 at yahoo.cn
Fri May 20 10:30:53 EDT 2011
Hello,everyone.
I am using the Mapserver to deploy a webgis system.And I've used the shp2tree tool to generate .qix File.
When I ZoomOut my web map,I found that,the more I zoomOut,Mapserver loads vector data more slow.Then I go to see the source code, I found that when the extent is bigger,it will search from the root to the bottom of the quadtree.
Is there anyway so solve the problem?And Is this a bug?
Wait for ur answers,thank you!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110520/f57d1a61/attachment.html
