[mapserver-users] OGRinfo works, but a MapServer test mode=map DOES NOT
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu May 26 10:16:19 EDT 2011
Hello,
Viewing SQLServer2008 data in MapServer with MS4W 3.0.1 is done through
a plugin, and you should follow instructions in your local MS4W README
file for this (such as
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#microsoft-sql-server-2008)
If you have any further questions, or comments, or problems with this,
please use the MS4W mailing list (subscribe at
http://lists.maptools.org/mailman/listinfo/ms4w-users)
Thank you.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-05-26 7:26 AM, Eduardo Kanegae wrote:
> Hi all,
> I´m running Windows Server 2008 R2 Enterprise SP1 64bits using MS4W
> 3.0.1 with MapServer CGI 5.6.6 grabed from MapTools.org
> My spatial data is on SQL Server 2008 + MsSqlSpatial 0.1.1 Lib and
> I´ve set an ODBC DSN connection using SQL Server Native Driver 10
> ( using Control Panel ->  ODBC Admin ->  System DSN and also
> C:\Windows\SysWOW64\odbcad32.exe tool )
> When I run ogrinfo using:
> $ ogrinfo -so "MSSQL:dsn=my_dsn;server=(local);database=my_database;tables=dbo.my_table;uid=my_user;pwd=my_passwd"
> my_table
> it works and dumps info like:
> INFO: Open of `MSSQL:dsn=nucoffee;server=(local);database=nucoffee;tables=dbo.fazendas2;uid=db_nucoffee;pwd=@&NuCoFfEe&@'
>        using driver `MSSQLSpatial' successful.
> ... and so on!
> BUT, when trying a MapServer CGI mode map request like:
> http://my_server/cgi-bin/mapserv.exe?map=e:/my_mapfile.map&mode=map&layers=all&map_size=800+600
> I only got the error:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'pol_my_layer'. msOGRFileOpen(): OGR error. Open failed for OGR
> connection in layer `pol_my_layer'. Unable to initialize ODBC
> connection to DSN for my_user/my_passwd at my_dsn, [Microsoft][ODBC
> Driver Manager] Data source name not found and no default driver
> specified
> Can anybody give me a clue on that?
> My LAYER mapfile part is defined as :
> LAYER
> 		NAME			"pol_my_layer"
> 		TYPE			POLYGON
> 		CONNECTIONTYPE OGR
> 		CONNECTION "<OGRVRTDataSource>
>      <OGRVRTLayer name='pol_my_layer'>
> 		<SrcDataSource>ODBC:my_user/my_passwd at my_dsn</SrcDataSource>
> 		<SrcLayer>dbo.vw_pol_my_spatial_view</SrcLayer>
> 		<LayerSRS>WGS84</LayerSRS>
> 		<GeometryType>wkbUnknown</GeometryType>
> 		<GeometryField encoding='WKB' field='geom_2005'/>
>      </OGRVRTLayer>
> </OGRVRTDataSource>"
> 		DATA "pol_my_layer"
> 		FILTER "329"
> 		FILTERITEM "farm_id"
> 		PROCESSING "CLOSE_CONNECTION=DEFER"
> 	END
> END
