[mapserver-users] OGRinfo works, but a MapServer test mode=map
DOES NOT
Eduardo Kanegae
eduardo.kanegae at gmail.com
Thu May 26 14:02:11 EDT 2011
Thanks Brent and Jeff for your suggestions.
My old scenario was:
- the system was running fine on Windows 2003 Server 64bits with SQL
2008+ MsSqlSpatial Lib using MapServer with ODBC
But now, the server was upgraded to Windows Server 2008 64bits with SQL 2008R2.
And the only way I finally found to put it to work was:
- use MSSQL OGR Driver but DOT NOT use geometry field type of SQL 2008
( absolutely slow! )
- instead of 2008 field I translate 2005 geom field ( MsSqlSpatial
lib) to WKT using:
... ST.AsText(v.geom_2005) AS geom_2008
And now it´s working!
Thanks for helping.
best
Eduardo Patto Kanegae
2011/5/26 Brent Fraser <bfraser at geoanalytic.com>:
> Eduardo,
> What happens when you use ogrinfo to access it via ODBC:
> ogrinfo ODBC:my_user/my_passwd at my_dsn
> or if you put the connection in a vrt file and use ogrinfo on it?
> Best Regards,
> Brent Fraser
> On 5/26/2011 4:26 AM, Eduardo Kanegae wrote:
>> Hi all,
>> I´m running Windows Server 2008 R2 Enterprise SP1 64bits using MS4W
>> 3.0.1 with MapServer CGI 5.6.6 grabed from MapTools.org
>> My spatial data is on SQL Server 2008 + MsSqlSpatial 0.1.1 Lib and
>> I´ve set an ODBC DSN connection using SQL Server Native Driver 10
>> ( using Control Panel -> ODBC Admin -> System DSN and also
>> C:\Windows\SysWOW64\odbcad32.exe tool )
>> When I run ogrinfo using:
>> $ ogrinfo -so
>> "MSSQL:dsn=my_dsn;server=(local);database=my_database;tables=dbo.my_table;uid=my_user;pwd=my_passwd"
>> my_table
>> it works and dumps info like:
>> INFO: Open of
>> `MSSQL:dsn=nucoffee;server=(local);database=nucoffee;tables=dbo.fazendas2;uid=db_nucoffee;pwd=@&NuCoFfEe&@'
>> using driver `MSSQLSpatial' successful.
>> ... and so on!
>> BUT, when trying a MapServer CGI mode map request like:
>> http://my_server/cgi-bin/mapserv.exe?map=e:/my_mapfile.map&mode=map&layers=all&map_size=800+600
>> I only got the error:
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'pol_my_layer'. msOGRFileOpen(): OGR error. Open failed for OGR
>> connection in layer `pol_my_layer'. Unable to initialize ODBC
>> connection to DSN for my_user/my_passwd at my_dsn, [Microsoft][ODBC
>> Driver Manager] Data source name not found and no default driver
>> specified
>> Can anybody give me a clue on that?
>> My LAYER mapfile part is defined as :
>> LAYER
>> NAME "pol_my_layer"
>> TYPE POLYGON
>> CONNECTIONTYPE OGR
>> CONNECTION "<OGRVRTDataSource>
>> <OGRVRTLayer name='pol_my_layer'>
>> <SrcDataSource>ODBC:my_user/my_passwd at my_dsn</SrcDataSource>
>> <SrcLayer>dbo.vw_pol_my_spatial_view</SrcLayer>
>> <LayerSRS>WGS84</LayerSRS>
>> <GeometryType>wkbUnknown</GeometryType>
>> <GeometryField encoding='WKB' field='geom_2005'/>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>"
>> DATA "pol_my_layer"
>> FILTER "329"
>> FILTERITEM "farm_id"
>> PROCESSING "CLOSE_CONNECTION=DEFER"
>> END
>> END
>> best regards,
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
