[mapserver-users] mapserver6 (was 5) postgis connection problem
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 27 08:32:19 EDT 2011
What happens if you try:
sudo -u <apache_user> ./mapserv -nh
"QUERY_STRING=map=osmwm.map&mode=map"> /tmp/test11.png
This might be a permission problem somewhere.
-Steve W
On 5/27/2011 5:18 AM, Richard Duivenvoorde wrote:
> Sorry for wrong subject, I'm talking about mapserver6 here.
> Ok, don't think it is a postgres/postgis problem...
> Installed geoserver, and that is serving fine ....
> Als0 tried mapserv from command line:
> ./mapserv -nh "QUERY_STRING=map=osmwm.map&mode=map"> /tmp/test11.png
> also ok
> mapfile snippet:
> LAYER
> NAME test
> TYPE polygon
> STATUS default
> DEBUG 5
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost dbname=osm password=sssst user=geo"
> DATA "way28992 from (select * from landuse2) as foo using unique
> osm_id using srid=28992"
> FILTER "landuse in ('industrial', 'residential')"
> METADATA
> "WMS_TITLE" "test"
> "WMS_SRS" "EPSG:28992"
> "OWS_EXTENT" "-26000 296000 293000 634000"
> END
> CLASS
> STYLE
> COLOR 255 0 0
> END
> STYLE
> OUTLINECOLOR 0 0 0
> WIDTH 3
> ANTIALIAS TRUE
> END
> END #CLASS
> END
> On 05/26/2011 11:58 PM, Richard Duivenvoorde wrote:
>> Like somebody else in the list I have a strange problem with MS6 on a
>> fresh RHEL6 machine. Running the same data and mapfile in an older MS works.
>> Below as much info I could get.
>> Anybody a clue?
>> I can recompile or add debug statements if nessecary (will be on irc
>> tomorrow morning)
>> Regards,
>> I fail to get a postgres connection log somewhere on this machine...
>> a new installed RHEL6 machine:
>> Red Hat Enterprise Linux Server release 6.0 (Santiago)
>> running
>> "PostgreSQL 8.4.8 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC)
>> 4.4.4 20100726 (Red Hat 4.4.4-13), 64-bit"
>> and
>> "1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
>> mapserver -v gives
>> MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> SUPPORTS=WCS_SERVER INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> I've done a gdal and mapserver compile myself
>> A database with OSM data and mapfile with connectionstring like:
>> CONNECTION "host=localhost dbname=osm password=xxxx user=geo"
>> keeps saying:
>> Permission denied Is the server running on host "localhost" and
>> accepting TCP/IP connections on port 5432? ) with connect string
>> 'host=localhost dbname=osm password=******* user=geo'
>> while:
>> - I can connect with that user/password via psql
>> - can use shp2img and the same mapfile (generating a map)
>> - can do
>> ogrinfo -ro PG:'host=localhost user=geo password=xxxxxx dbname=osm' -sql
>> "select count(*) from mytable"
>> - even tried trust for all hosts in pg_hba.conf
>> setting debug in LAYER at 5
>> -- first part is from wms request (failing connection):
>> [Thu May 26 23:45:30 2011].566614 msPostGISLayerOpen called: way28992
>> from nl_osm_point using unique osm_id using srid=28992
>> [Thu May 26 23:45:30 2011].566704 msPostGISLayerOpen: No connection in
>> pool, creating a fresh one.
>> [Thu May 26 23:45:30 2011].568103 msPostGISLayerOpen: Connection failure.
>> [Thu May 26 23:45:30 2011].568123 msPostGISLayerOpen(): Query error.
>> Database connection failed (could not connect to server: Permission denied
>> Is the server running on host "localhost" and accepting
>> ) with connect string 'host=localhost dbname=osm password=******* user=geo'
>> Is the database running? Is it allowing connections? Does the specified
>> user exist? Is the password valid? Is the database on the standard port?
>> [Thu May 26 23:45:30 2011].568138 msDrawMap(): Image handling error.
>> Failed to draw layer named 'plaatsen'.
>> [Thu May 26 23:45:30 2011].568224 msPostGISLayerClose called: way28992
>> [Thu May 26 23:45:30 2011].568238 freeLayer(): freeing layer at 0x1c67250.
>> [Thu May 26 23:45:30 2011].568243 msPostGISLayerIsOpen called.
>> [Thu May 26 23:45:30 2011].568251 freeLayer(): freeing layer at 0x1c6a7f0.
>> [Thu May 26 23:45:30 2011].568255 msPostGISLayerIsOpen called.
>> -- This part is from shp2img (connection succesfull):
>> [Thu May 26 23:47:55 2011].3388 msLayerIsVisible(): Skipping layer
>> (plaatsen) because no CLASS in the layer is in-scale for this MAP scale
>> [Thu May 26 23:47:55 2011].3450 msLayerIsVisible(): Skipping layer
>> [Thu May 26 23:47:55 2011].3457 msLayerIsVisible(): Skipping layer
>> [Thu May 26 23:47:55 2011].3470 msPostGISLayerOpen called: way28992 from
>> (select way28992, z_order, landuse, osm_id, name from nl_osm_polygon
>> order by z_order) as foo using unique osm_id using srid=28992
>> [Thu May 26 23:47:55 2011].3478 msPostGISLayerOpen: No connection in
>> [Thu May 26 23:47:55 2011].16884
>> msConnPoolRegister(residentialandindustry,host=localhost dbname=osm
>> password=xxxx user=geo,0x18ff430)
>> [Thu May 26 23:47:55 2011].27950 msPostGISLayerOpen: Got PostGIS version
>> 10500.
>> [Thu May 26 23:47:55 2011].27963 msPostGISLayerFreeItemInfo called.
>> [Thu May 26 23:47:55 2011].27971 msPostGISLayerInitItemInfo called.
>> [Thu May 26 23:47:55 2011].27986 msPostGISLayerWhichShapes called.
>> [Thu May 26 23:47:55 2011].27992 msPostGISParseData called.
>> [Thu May 26 23:47:55 2011].28008 msPostGISParseData:
>> unique_column=osm_id, srid=28992, geom_column_name=way28992,
>> table_name=(select way28992, z_order, landuse, osm_id, name from
>> nl_osm_polygon order by z_order) as foo
>> [Thu May 26 23:47:55 2011].28012 msPostGISBuildSQL called.
>> [Thu May 26 23:47:55 2011].28016 msPostGISBuildSQLItems called.
>> [Thu May 26 23:47:55 2011].28021 msPostGISBuildSQLItems: 2 items requested.
>> [Thu May 26 23:47:55 2011].28025 msPostGISBuildSQLFrom called.
>> [Thu May 26 23:47:55 2011].28031 msPostGISBuildSQLWhere called.
>> [Thu May 26 23:47:55 2011].28034 msPostGISBuildSQLSRID called.
>> [Thu May 26 23:47:55 2011].28038 msPostGISBuildSQLSRID: SRID provided
>> (28992)
>> [Thu May 26 23:47:55 2011].28041 msPostGISBuildSQLBox called.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
