[mapserver-users] mapserver6 (was 5) postgis connection problem
Richard Duivenvoorde rdmailings at duif.net
Fri May 27 11:24:11 EDT 2011
On 05/27/2011 04:36 PM, Carlos Ruiz wrote:
> I can see a "sssst" password (5 chars) with Geoserver test and a
> "*******" password (7 chars) with Mapserver test, are you sure
> that you're using the same password ???
The sssst is just me hiding a password. And if that was the problem, the
command line calls would have failed also?
> Also, if you're using HBA, you have to do the Geoserver and the
> Mapserver test in the same machine because the ip address.
both database, mapserver and geoserver are all on 1 virtual machine.
Thanks,
Richard
