[mapserver-users] Re: mapserver6 (was 5) postgis connection problem
nikos at maich.gr nikos at maich.gr
Mon May 30 01:07:19 EDT 2011
 I don't know if it is relevant, but I get a no route to host when I
 test that ip via pgadmin, meaning tcp connections will fail, whereas
 local connections should not as they are IPC based. Does postgis use
 tcp/ip by default for connecting?
 regards,
 nikos
