[mapserver-users] HTTP request error. CURLOPT_PROXYAUTH not supported. Requires Curl 7.10.7 and up
sulu andreas.siegel at vorarlberg.at
Tue May 31 03:50:01 EDT 2011
Hello.
Im struck with
and up
whenever i try to use proxy authentification.
I use mapserver 5.6.6 built from Source on a centos-linux-box.
Configure-statement:
./configure --with-proj=/usr/local --with-gdal=/usr/bin/gdal-config
--with-ogr=/usr/bin/gdal-config --with-fastcgi=/usr --with-wfs
--with-postgis=/usr/bin/pg_config --with-xml2-config=/usr/bin
--with-wmsclient  --with-wfsclient
I found a thread from April-2011 covering the same issue but i could not
figure out a solution for myself.
But in that thread a compiler-option
-DUSE_CURL -DCURLOPT_PROXYAUTH
caught my eye.
Is this -DUSE_CURL -DCURLOPT_PROXYAUTH the solution to my problem and how to
enable it?
Cheers
Andy
View this message in context: http://osgeo-org.1803224.n2.nabble.com/HTTP-request-error-CURLOPT-PROXYAUTH-not-supported-Requires-Curl-7-10-7-and-up-tp6421746p6421746.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
