[mapserver-users] SLD with filter
Daniel Degasperi
daniel.degasperi at r3-gis.com
Tue May 31 08:26:10 EDT 2011
I've a problem with following filter:
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:PropertyIsEqualTo matchCase="true">
<ogc:PropertyName>localita</ogc:PropertyName>
<ogc:Literal>1.102</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
Output:
<?xml version="1.0" encoding="ISO-8859-1"?>
<ows:ExceptionReport
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ows="http://www.opengis.net/ows" version="1.1.0" language="en-US"
xsi:schemaLocation="http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="mapserv" locator="NoApplicableCode">
<ows:ExceptionText>msWFSGetFeature(): WFS server error.
FLTApplyFilterToLayer() failed
msPostGISLayerWhichShapes(): Query error. Error (ERROR: operator does
not exist: text = numeric
LINE 1: ...6966392 4130435.36164853))',32632) and ( (localita= 1.102) )
HINT: No operator matches the given name and argument type(s). You
might need to add explicit type casts.
) executing query: select
"gc_objid","di_id","localita","di_name_1",encode(AsBinary(force_collection(force_2d("the_geom")),'NDR'),'hex')
as geom,"gc_objid" from (SELECT __data__.di_id as
gc_objid,__data__.the_geom,
__data__.di_id,__data__.localita,__data__.di_name_1 FROM
geo.district_area AS __data__) AS foo where the_geom &&
GeomFromText('POLYGON((-393764.596966392
4130435.36164853,-393764.596966392 5936656.6234314,1412456.59042116
5936656.6234314,1412456.59042116 4130435.36164853,-393764.596966392
4130435.36164853))',32632) and ( (localita= 1.102) )</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
It seems that the value 1.102 is not quoted. Should I add the attribute
xs:type="string" to the literal node or use the PropertyIsLike condition?
I'm using MapServer 5.6.6
Best regards,
Daniel
Daniel Degasperi R3 GIS Srl - GmbH www.r3-gis.com
