[mapserver-users] SLD with filter
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue May 31 08:37:11 EDT 2011
Hi Daniel,
You could possibly try to set on the layer a metadata for the type of
your field to force it to string: something like
metadata
"ows_localita_type" "Character"
end
regards,
On 31/05/2011 8:26 AM, Daniel Degasperi wrote:
> Hi,
> I've a problem with following filter:
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> <ogc:PropertyIsEqualTo matchCase="true">
> <ogc:PropertyName>localita</ogc:PropertyName>
> <ogc:Literal>1.102</ogc:Literal>
> </ogc:PropertyIsEqualTo>
> </ogc:Filter>
> Output:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <ows:ExceptionReport
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ows="http://www.opengis.net/ows" version="1.1.0"
> language="en-US" xsi:schemaLocation="http://www.opengis.net/ows
> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
> <ows:Exception exceptionCode="mapserv" locator="NoApplicableCode">
> <ows:ExceptionText>msWFSGetFeature(): WFS server error.
> FLTApplyFilterToLayer() failed
> msPostGISLayerWhichShapes(): Query error. Error (ERROR: operator does
> not exist: text = numeric
> LINE 1: ...6966392 4130435.36164853))',32632) and ( (localita= 1.102) )
> HINT: No operator matches the given name and argument type(s). You
> might need to add explicit type casts.
> ) executing query: select
> "gc_objid","di_id","localita","di_name_1",encode(AsBinary(force_collection(force_2d("the_geom")),'NDR'),'hex')
> as geom,"gc_objid" from (SELECT __data__.di_id as
> gc_objid,__data__.the_geom,
> __data__.di_id,__data__.localita,__data__.di_name_1 FROM
> geo.district_area AS __data__) AS foo where the_geom &&
> GeomFromText('POLYGON((-393764.596966392
> 4130435.36164853,-393764.596966392 5936656.6234314,1412456.59042116
> 5936656.6234314,1412456.59042116 4130435.36164853,-393764.596966392
> 4130435.36164853))',32632) and ( (localita= 1.102) )</ows:ExceptionText>
> </ows:Exception>
> </ows:ExceptionReport>
> It seems that the value 1.102 is not quoted. Should I add the
> attribute xs:type="string" to the literal node or use the
> PropertyIsLike condition?
> I'm using MapServer 5.6.6
> Best regards,
> Daniel
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
