[mapserver-users] GetMap Issue
Asad Ullah
Asad.Ullah at sigmaspace.com
Thu Nov 3 13:03:47 EDT 2011
List,
I have an issue with getting a composite map of a number of layers. As you see it only return the top layer whereas it should show a multilayer image. Any help would really be appreciated.
My url is something like:
http://lance2.modaps.eosdis.nasa.gov/cgi-bin/mapserv.cgi?map=usecase_all_download_20111102.map&LAYERS=Terra250+Terra_snow_cover+fires24+Admin_Bound&mode=map&imgext=-94.4722+28.7876+-88.6714+33.2041&mapext=-94.4722+28.7876+-88.6714+33.2041&map_size=2640.327719617658+2010.2412380518867&imgx=2640.327719617658&imgy=2010.2412380518867&imgxy=2640.327719617658+2010.2412380518867&map_imagetype=JPEG
and my part of mapfile is:
MAP
NAME "usecase"
UNITS dd
MAXSIZE 20000
SIZE 1600 1200
IMAGECOLOR -1 -1 -1
IMAGETYPE "AGG"
SHAPEPATH "/MODAPSweb"
PROJECTION
"init=epsg:4326"
END
EXTENT -178.00 -80.00 183.00 80.00
WEB
IMAGEPATH "/MODAPSweb/www/wms/tmp/"
IMAGEURL "/tmp/"
END
LAYER
NAME "Terra250"
TYPE RASTER
STATUS ON
OFFSITE 0 0 0
PROJECTION
"init=epsg:4326"
END
DATA "share/vrtfile/terr_250m_2011306.vrt"
CLASS
STYLE
BACKGROUNDCOLOR 255 255 255
END
END
END
LAYER
NAME "Admin_Bound"
TYPE LINE
STATUS ON
PROJECTION
"init=epsg:4326"
END
DATA "share/vrtfile/esri-administrative-boundaries_level-1"
CLASS
STYLE
COLOR 0 0 0
WIDTH 0.5
END
END
END
LAYER
NAME "Terra_snow_cover"
TYPE RASTER
STATUS ON
OFFSITE 0 0 0
PROJECTION
"init=epsg:4326"
END
DATA "share/vrtfile/MOR10FSCLLDY_2011306.vrt"
VALIDATION
'DATA' '^MOR10FSCLLDY_.*\.vrt$'
END
CLASS
STYLE
BACKGROUNDCOLOR -1 -1 -1
END END
END
LAYER
NAME "fires24"
TYPE RASTER
STATUS ON
TRANSPARENCY 100
OFFSITE 255 255 255
CONNECTION "http://firefly.geog.umd.edu/wms/wms?"
CONNECTIONTYPE WMS
METADATA
"wms_title" "Fires - Past 24 hours"
"wms_name" "fires24"
"wms_onlineresource" "http://firefly.geog.umd.edu/wms/wms?"
"wms_srs" "EPSG:4326"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
END
PROJECTION
"init=epsg:4326"
END
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
TRANSPARENT ON
END
OUTPUTFORMAT
NAME "agg"
DRIVER AGG/PNG
IMAGEMODE RGBA
END
OUTPUTFORMAT
NAME 'AGG'
DRIVER "AGG/jpeg"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
END
Thanks,
Asad
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111103/9e2e6a24/attachment.html
