[mapserver-users] GetMap Issue
    Asad Ullah
    Asad.Ullah at sigmaspace.com
    Thu Nov  3 10:03:47 PDT 2011
List,
I have an issue with getting a composite map of a number of layers. As you see it only return the top layer whereas it should show a multilayer image.  Any help would really be appreciated.
My url is something like:
http://lance2.modaps.eosdis.nasa.gov/cgi-bin/mapserv.cgi?map=usecase_all_download_20111102.map&LAYERS=Terra250+Terra_snow_cover+fires24+Admin_Bound&mode=map&imgext=-94.4722+28.7876+-88.6714+33.2041&mapext=-94.4722+28.7876+-88.6714+33.2041&map_size=2640.327719617658+2010.2412380518867&imgx=2640.327719617658&imgy=2010.2412380518867&imgxy=2640.327719617658+2010.2412380518867&map_imagetype=JPEG
and my part of mapfile is:
MAP
NAME "usecase"
UNITS dd
MAXSIZE 20000
SIZE 1600 1200
IMAGECOLOR -1 -1 -1
IMAGETYPE  "AGG"
SHAPEPATH "/MODAPSweb"
PROJECTION
    "init=epsg:4326"
END
 EXTENT -178.00 -80.00 183.00 80.00
WEB
    IMAGEPATH "/MODAPSweb/www/wms/tmp/"
    IMAGEURL "/tmp/"
END
LAYER
 NAME "Terra250"
    TYPE RASTER
    STATUS ON
    OFFSITE 0 0 0
  PROJECTION
    "init=epsg:4326"
  END
  DATA "share/vrtfile/terr_250m_2011306.vrt"
    CLASS
          STYLE
            BACKGROUNDCOLOR 255 255 255
          END
    END
END
  LAYER
    NAME "Admin_Bound"
    TYPE LINE
    STATUS ON
  PROJECTION
    "init=epsg:4326"
  END
    DATA "share/vrtfile/esri-administrative-boundaries_level-1"
      CLASS
    STYLE
        COLOR 0 0 0
        WIDTH 0.5
          END
      END
   END
LAYER
 NAME "Terra_snow_cover"
    TYPE RASTER
    STATUS ON
    OFFSITE 0 0 0
  PROJECTION
    "init=epsg:4326"
  END
DATA "share/vrtfile/MOR10FSCLLDY_2011306.vrt"
VALIDATION
  'DATA' '^MOR10FSCLLDY_.*\.vrt$'
END
    CLASS
          STYLE
            BACKGROUNDCOLOR -1 -1 -1
          END                        END
END
LAYER
          NAME "fires24"
          TYPE RASTER
          STATUS ON
    TRANSPARENCY 100
    OFFSITE 255 255 255
          CONNECTION "http://firefly.geog.umd.edu/wms/wms?"
          CONNECTIONTYPE WMS
          METADATA
            "wms_title"                     "Fires - Past 24 hours"
        "wms_name"                "fires24"
            "wms_onlineresource"            "http://firefly.geog.umd.edu/wms/wms?"
            "wms_srs"                       "EPSG:4326"
            "wms_server_version"            "1.1.1"
            "wms_format"                    "image/png"
          END
    PROJECTION
        "init=epsg:4326"
     END
        END
OUTPUTFORMAT
  NAME png
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE RGBA
  EXTENSION "png"
  TRANSPARENT ON
END
OUTPUTFORMAT
  NAME "agg"
  DRIVER AGG/PNG
  IMAGEMODE RGBA
END
OUTPUTFORMAT
  NAME 'AGG'
  DRIVER "AGG/jpeg"
  MIMETYPE "image/jpeg"
  IMAGEMODE RGB
  EXTENSION "jpg"
END
END
Thanks,
Asad
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111103/9e2e6a24/attachment.htm>
More information about the MapServer-users
