[mapserver-users] How to join to a MDB database for display on my
map?
boesiii
boesiii at yahoo.com
Fri Nov 18 11:22:58 EST 2011
I have a polygon shapefile showing parcel outlines and an access database
containing owner names. I would like add a layer displaying the owner name
but after reading the MapServer documentation "You cannot use joins to
affect the look of a map", I realize this is not possible.
Is there any other way to accomplish what I am trying to do?
Is there an OGR/GDAL command line function that will export the table from
the MDB to DBF file?
I know I can join the files together using ESRI ArcGIS but was hoping to
leave the files in the original format because the data is maintained by
someone else.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-join-to-a-MDB-database-for-display-on-my-map-tp7008818p7008818.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
