[mapserver-users] mod-geocache to mod-mapcache transition...
thomas bonfort
thomas.bonfort at gmail.com
Mon Nov 28 14:37:28 EST 2011
Stve, can you provide a backtrace for this:
- apachectl stop
- gdb /usr/sbin/httpd (or whatever the path is to the httpd binary)
- # run -X
thomas
On Mon, Nov 28, 2011 at 19:46, Lime, Steve D (DNR)
<Steve.Lime at state.mn.us> wrote:
> I'm getting a segfault trying to access any images. Config file is the same except for the opening block. Can the modules be run together? The demos run for both although the mapcache image calls all
> Segfault. The layer list is there so it's parsing the config- there are actually more layers at
> /mapcache/demo/wms than the geocache setup (WMS and singleTile).
> Steve
> -----Original Message-----
> From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
> Sent: Monday, November 28, 2011 11:56 AM
> To: Lime, Steve D (DNR)
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] mod-geocache to mod-mapcache transition...
> aside from the opening block called <mapcache> instead of <geocache>
> they should be indentical.
> recent mapcache will work with the same caches as modgeocache, except
> for the WGS84 preconfigured grid where the zoom level numbering has
> changed (mod-geocache's zoom level 0 has been deleted, it's level 1 is
> now mapcache's level 0)
> thomas
> On Mon, Nov 28, 2011 at 18:50, Lime, Steve D (DNR)
>> Hi all: I’m currently running somewhat recent mod-geocache from trunk
>> successfully and would like to move to mod-mapcache. Does mod-mapcache use
>> the same config format (looks like it) and can it work off tiles generated
>> by mod-geocache?
>> Steve
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
