[mapserver-users] bug in mapscript colorObj ?
Daniel Morissette
dmorissette at mapgears.com
Sat Oct 1 10:45:12 EDT 2011
On 11-09-30 07:12 AM, Jachym Cepicky wrote:
> Hi,
> I try to set transparent color to REFERENCE map, so that the box is
> outlined-only.
> According to documentation, i use -1 for indication, that the color
> should be transparent
> color = mapscript.colorObj(-1,-1,-1)
How do you set/assign the color value to the reference map object? What
if you set another color than -1,-1,-1, does it get through?
The following works fine for me in PHP MapScript. Perhaps make a similar
test with the version of MapScript you are using (Python?), and then
look at the output of /tmp/test.map to comfirm that the color is set as
expected.
<?php
$map = ms_newMapObj("/path/to/my.map");
$map->reference->color->setRGB(-1,-1,-1);
$map->save("/tmp/test.map");
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
