[mapserver-users] Projection library error. no system list, errno: 2
Daniel Morissette dmorissette at mapgears.com
Mon Oct 3 08:13:29 EDT 2011
What does your PROJECTION block look like?
Could it be that you used something like "init=EPSG:4326"? Linux is
case-sensitive and the argument to the init=... param is a filename so
you must use a lowercase "epsg" in the init string, e.g. "init=epsg:4326"
On 11-10-02 03:59 PM, Richard Greenwood wrote:
> All-
> I'm getting the following error from mapserver:
>     msProcessProjection(): Projection library error. no system list, errno: 2
> I have a fresh install of Ubuntu Lucid with standard mapserer&  gdal
> packages. I see
>     /usr/share/proj/epsg
> which includes the EPSG code that I am referencing.
> I have added
>     CONFIG PROJ_LIB "/usr/share/proj/"
> to my map file.
> cs2cs in the shell seems to find and use the epsg file.
> I have even tried changing the ownership of the epsg file to www-data
> (the Ubuntu web account). I don't see any PROJ_LIB definitions in the
> apache *.conf files.
> So I'm kind of at my wits end. Any suggestions?
> Thanks,
> Rich
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
