[mapserver-users] Feature wish: Internal mapfile variables
Daniel Morissette dmorissette at mapgears.com
Mon Oct 3 08:57:19 EDT 2011
I agree that this is a request that comes up often. As usual we'd just
need someone to lead the effort.
On 11-10-03 12:12 AM, Rahkonen Jukka wrote:
> Hi,
> Inspired by the Thomas Bonfort's rendering chain I have been thinking if we could have a native support for using  internal mapfile variables.  Now Thomas is setting for example a bunch of colours in a definition file which is converted into a real mapfile with python script and c preprocessor.
> http://mapserver-utils.googlecode.com/svn/trunk/README
> http://mapserver-utils.googlecode.com/svn/trunk/generate_style.py
> I would like to see a simple way for setting the variables directly in the mapfile, somehow like
> MAP
> SET "pedestrian_clr"  "#fafaf5"
> SET "forest_clr" "#dcdcb4"
> SET "industrial_clr" "#ebe5d9"
> And then later in the layers use
> LAYER
> COLOR %pedestrian_clr%
> The internal variables could be interpreted only from the mapfile and they could not be altered by the web users.
> Internal variable would help in maintaining big mapfiles with repeating styles like in the OpenStreetMap rendering case.  Another use case is when the same layers are re-used for several customers who like to have a bit different styling for the same source data.
> -Jukka Rahkonen-
> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
