[mapserver-users] MapCache - failed to remove lockfile error
Travis Kirstine traviskirstine at gmail.com
Thu Oct 6 09:52:05 EDT 2011
Thanks Thomas,
The complete error message is below.  Do you have any idea what would
cause this error - why would mapcache fail to create or delete the
lockfile.
seeding tile 583296 1337304 21failed to remove lockfile
/var/mod-geocache/cachesseeding tile 583304 1337296 21failed to remove
lockfile /var/mod-geocache/caches/_gc_lock-21-167156-72919-ms_tileset_8:
No such file or directoryfailed to remove lockfile
/var/mod-geocache/caches/_gc_lock-21-167157-72919-ms_tileset_8: No
/var/mod-geocache/caches/_gc_lock-20-83579-36459-ms_tileset_8: No such
/var/mod-geocache/caches/_gc_lock-21-167156-72918-ms_tileset_8: No
/var/mod-geocache/caches/_gc_lock-21-167159-72918-ms_tileset_8: No
/var/mod-geocache/caches/_gc_lock-21-167158-72918-ms_tileset_8: No
/var/mod-geocache/caches/_gc_lock-21-167159-72919-ms_tileset_8: No
/var/mod-geocache/caches/_gc_lock-18-20895-9114-ms_tileset_8: No such
/var/mod-geocache/caches/_gc_lock-21-167158-72919-ms_tileset_8: No
Regards
On 6 October 2011 09:11, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> The log message should be more explicit, and contain the reason of the
> unsuccessful removal. In any case, looking at the code, this error
> will have interrupted the seeding process.
> regards,
> thomas
> On Thu, Oct 6, 2011 at 15:03, Travis Kirstine <traviskirstine at gmail.com> wrote:
>> Hi All,
>> I hope this is the right spot to post MapCache questions.  I had
>> seeded a large area and receive the error "failed to remove lockfile".
>>  It appears that this error(s) happens at the end of the seeding but
>> it is hard tell as the process has been running for a few days.  Does
>> this error kill the seeder process or is it simply a warning?
>> Regards
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
