[mapserver-users] MapCache - failed to remove lockfile error
thomas bonfort
thomas.bonfort at gmail.com
Thu Oct 6 10:31:55 EDT 2011
what seed command were you using, and what kind of cache ?
On Thu, Oct 6, 2011 at 15:52, Travis Kirstine <traviskirstine at gmail.com> wrote:
> Thanks Thomas,
> The complete error message is below. Do you have any idea what would
> cause this error - why would mapcache fail to create or delete the
> lockfile.
> seeding tile 583296 1337304 21failed to remove lockfile
> /var/mod-geocache/cachesseeding tile 583304 1337296 21failed to remove
> lockfile /var/mod-geocache/caches/_gc_lock-21-167156-72919-ms_tileset_8:
> No such file or directoryfailed to remove lockfile
> /var/mod-geocache/caches/_gc_lock-21-167157-72919-ms_tileset_8: No
> /var/mod-geocache/caches/_gc_lock-20-83579-36459-ms_tileset_8: No such
> /var/mod-geocache/caches/_gc_lock-21-167156-72918-ms_tileset_8: No
> /var/mod-geocache/caches/_gc_lock-21-167159-72918-ms_tileset_8: No
> /var/mod-geocache/caches/_gc_lock-21-167158-72918-ms_tileset_8: No
> /var/mod-geocache/caches/_gc_lock-21-167159-72919-ms_tileset_8: No
> /var/mod-geocache/caches/_gc_lock-18-20895-9114-ms_tileset_8: No such
> /var/mod-geocache/caches/_gc_lock-21-167158-72919-ms_tileset_8: No
> Regards
> On 6 October 2011 09:11, thomas bonfort <thomas.bonfort at gmail.com> wrote:
>> The log message should be more explicit, and contain the reason of the
>> unsuccessful removal. In any case, looking at the code, this error
>> will have interrupted the seeding process.
>> regards,
>> thomas
>> On Thu, Oct 6, 2011 at 15:03, Travis Kirstine <traviskirstine at gmail.com> wrote:
>>> Hi All,
>>> I hope this is the right spot to post MapCache questions. I had
>>> seeded a large area and receive the error "failed to remove lockfile".
>>> It appears that this error(s) happens at the end of the seeding but
>>> it is hard tell as the process has been running for a few days. Does
>>> this error kill the seeder process or is it simply a warning?
>>> Regards
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
