[mapserver-users] Re: Re: WMS-TIME with mysql-database
Katharina Sambs KSambs at BfS.de
Mon Oct 17 05:03:58 EDT 2011
Good morning,
thank you, for your answer!
I set up a wms-time service with a PostGIS database, too.
It works fine, as well as the shapefile service.
Only with the mySQL database I get a *white* result.
Does anyone know if there is a general problem with wms-time and spatial mySQL data?
Unfortunately, the wider extent doesn´t help.
My request:
http:...&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=46.556819,5.188080,55.865300,15.000000&CRS=EPSG:4326&WIDTH=1017&HEIGHT=963&
LAYERS=layer&STYLES=&FORMAT=image/png&DPI=96&TRANSPARENT=TRUE
My mapfile:
MAP
    NAME "name"
    STATUS ON
    EXTENT -180 -90 180 90
    UNITS METERS
    INCLUDE "debug.map"
    SYMBOLSET "symbols.sym"
    FONTSET "fonts.list"
    INCLUDE "encryption.map"
    INCLUDE "projection_4326.map"
    WEB
        INCLUDE "image_parameter.map"
        METADATA
            OWS_ENABLE_REQUEST   "*"
            WMS_ONLINERESOURCE    "..."
            WMS_TITLE    "..."
            WMS_FEATURE_INFO_MIME_TYPE    "text/html"
            WMS_ABSTRACT    "..."
            INCLUDE "standard_extent_europa.map"
            INCLUDE "standard_proj.map"
            #INCLUDE "standard_metadata.map"
        END
    END
    INCLUDE "outputformat_agg.map"
    INCLUDE "legend.map"
    LAYER
        NAME "layer"
        TYPE POINT
        STATUS ON
        INCLUDE "debug_layer.map" #2 Zeilen
        DUMP TRUE
        TOLERANCE 3
        PROCESSING "CLOSE_CONNECTION=DEFER"
        CONNECTIONTYPE OGR
        CONNECTION "MYSQL:test,host=host,user=user,password=passwort,port=port,tables=tabelle"
	DATA "SELECT column1, column2 FROM tabelle"
        CLASS
          STYLE
            OUTLINECOLOR 100 100 100
          END
        END
        METADATA
            WMS_TITLE    "title"
            WMS_TIMEEXTENT	"2011-10-13T00:00:00Z/2011-10-14T00:00:00Z"
            WMS_TIMEITEM	"column1"
  	    WMS_TIMEDEFAULT "2011-10-13T00:00:00Z"
            WMS_ABSTRACT    "..."
            INCLUDE "standard_extent.map"
            LAYER_TITLE "..."
            LAYER_DESC_STATUS "on"
            LAYER_DESC "..."
            gml_include_items "all"
        END
    END #LAYER
END #MAP
my humble suggestion is inline.
I have done WMS Time successfully for PostGIS.
Den 14.10.2011 13:55, skrev Katharina Sambs:
> > Hi list,
> > I would like to visualize spatial *mySQL* data through a wms-time
> > service.
> > *It is possible to visualize the data without the time parameters.*
> > But as soon as I add the following parameters to the mapfile, my
> > result contains only a white picture:
> > LAYER
> >    METADATA
> >        WMS_TIMEEXTENT   "2010-01-10T00:00:00Z"
> >        WMS_TIMEITEM   "column_name"
> >        WMS_TIMEDEFAULT   "2010-01-10T00:00:00Z"
> > There is no error message.
> > *The same request works fine, while I use a shapefile as data source.*
> > My second question:
> > Shouldn't be there a 'where'-clause in the database selection, which
> > contain the time parameter?
I don't think so,
> > Or works the wms-time like a Filter, which always ask all data from
> > the database.
> > Only in the second step, the data is filtered for the desired time?
This filter should be added by Mapserver automagically when you have
WMS_TIME* in METADATA field.
> > Did anyone has an idea?
You extent should maybe be more "wide".
 From http://mapserver.org/ogc/wms_time.html
/value/ - a single value. This is not directly supported in MapServer
but there is an easy workwound by specifying the same value as min and max.
I have always used extents similar to the example in the docs:
"wms_timeextent"  "2004-01-01/2004-02-01"
If this is not helping, you should attach (important parts of) mapfile
and URL request.
kind regards
Jørn Vegard Røsnes
> > The type of the time data in the mySQL database is "DATETIME".
> > mysql.log
> > 111014 13:27:45     4 Connect  user at server on database
> >      4 Query DESCRIBE `table`
> >      4 Query SELECT type, coord_dimension FROM geometry_columns WHERE
> > f_table_name='table'
> >      4 Query SELECT srid FROM geometry_columns WHERE f_table_name =
> > 'table'
> >      4 Query SELECT column1, column2 FROM table
> >      4 Query SELECT type FROM geometry_columns WHERE f_table_name='table'
> > 'table'
> >      4 Quit
> > mapserv.log:
> > [Fri Oct  7 16:05:42 2011].982953 CGI Request 1 on process 18953
> > [Fri Oct  7 16:05:42 2011].983461 msWMSLoadGetMapParams(): enabling
> > non-square pixels.
> > [Fri Oct  7 16:05:42 2011].990638 msDrawMap(): kicking into non-square
> > pixel preserving mode.
> > [Fri Oct  7 16:05:42 2011].991160
> > msOGRFileOpen(MYSQL:tabelle,host=host,user=user,password=passwort,port=port)...
> > [Fri Oct  7 16:05:42 2011].991205
> > OGROPen(MYSQL:tabelle,host=host,user=readonly,password=readonly,port=port)
> > [Fri Oct  7 16:05:43 2011].20413
> > msConnPoolRegister(layer,MYSQL:tabelle,host=host,user=readonly,password=passwort,port=port,0x5417290)
> > [Fri Oct  7 16:05:43 2011].67656
> > msOGRLayerClose(MYSQL:tabelle,host=host,user=readonly,password=passwort,port=port).
> > [Fri Oct  7 16:05:43 2011].67662
> > msOGRFileClose(MYSQL:tabelle,host=host,user=readonly,password=readonly,port=port,-1).
> > [Fri Oct  7 16:05:43 2011].67672
> > msConnPoolRelease(layer,MYSQL:tabelle,host=host,user=readonly,password=passwort,port=port,0x5417290)
> > [Fri Oct  7 16:05:43 2011].67675
> > msConnPoolClose(MYSQL:tabelle,host=host,user=readonly,password=passwort,port=port,0x5417290)
> > [Fri Oct  7 16:05:43 2011].67849 msDrawMap(): Layer 2 (layer), 0.077s
> > [Fri Oct  7 16:05:43 2011].67867 msDrawMap(): Drawing Label Cache, 0.000s
> > [Fri Oct  7 16:05:43 2011].67871 msDrawMap() total time: 0.084s
> > [Fri Oct  7 16:05:43 2011].170031 msSaveImage() total time: 0.102s
> > [Fri Oct  7 16:05:43 2011].170228 mapserv request processing time
> > (msLoadMap not incl.): 0.187s
> > [Fri Oct  7 16:05:43 2011].170234 msFreeMap(): freeing map at 0x4f6cf30.
> > getCapabilities:
> > <Layer queryable="0" opaque="0" cascaded="0">
> > <Name>layer</Name>
> > <Title>title</Title>
> > <Abstract>abstract</Abstract>
> > <CRS>EPSG:4326</
> > <EX_GeographicBoundingBox>
> > <westBoundLongitude>5.18808</westBoundLongitude>
> > <eastBoundLongitude>15</eastBoundLongitude>
> > <southBoundLatitude>46.5582</southBoundLatitude>
> > <northBoundLatitude>55.8653</northBoundLatitude>
> > </EX_GeographicBoundingBox>
> > <BoundingBox CRS="EPSG:4326" minx="46.5582" miny="5.18808"
> > maxx="55.8653" maxy="15"/>
> > <Dimension name="time" units="ISO8601" default="2010-01-10T00:00:00Z"
> > nearestValue="0">2010-01-10T00:00:00Z</Dimension>
> > </Layer>
> > mysql version: 5.5.10-log
> > MapServer version 5.6.5
Mit freundlichen Grüßen
Katharina Sambs
