[mapserver-users] Re: Re: WMS-TIME with mysql-database
Stephan Holl stephan.holl at intevation.de
Mon Oct 17 06:24:37 EDT 2011
Hello Katharina,
Katharina Sambs <KSambs at BfS.de>, [20111017 - 11:03:58]
> Good morning,
> thank you, for your answer!
> I set up a wms-time service with a PostGIS database, too.
> It works fine, as well as the shapefile service.
> Only with the mySQL database I get a *white* result.
> Does anyone know if there is a general problem with wms-time and
> spatial mySQL data?
I would guess it has something in common with the (somewhat limited)
MySQL-support of OGR. I had problems with the MySQL-driver of OGR too
so I decided skipping it. I would digg into that area for further
investigation, enabling OGRs DEBUG-output etc...).
Best
	Stephan Holl
> Unfortunately, the wider extent doesn´t help.
> My request:
> http:...&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=46.556819,5.188080,55.865300,15.000000&CRS=EPSG:4326&WIDTH=1017&HEIGHT=963&
> LAYERS=layer&STYLES=&FORMAT=image/png&DPI=96&TRANSPARENT=TRUE
> My mapfile:
> MAP
>     NAME "name"
>     STATUS ON
>     EXTENT -180 -90 180 90
>     UNITS METERS
>     INCLUDE "debug.map"
>     SYMBOLSET "symbols.sym"
>     FONTSET "fonts.list"
>     INCLUDE "encryption.map"
>     INCLUDE "projection_4326.map"
>     WEB
>         INCLUDE "image_parameter.map"
>         METADATA
>             OWS_ENABLE_REQUEST   "*"
>             WMS_ONLINERESOURCE    "..."
>             WMS_TITLE    "..."
>             WMS_FEATURE_INFO_MIME_TYPE    "text/html"
>             WMS_ABSTRACT    "..."
>             INCLUDE "standard_extent_europa.map"
>             INCLUDE "standard_proj.map"
>             #INCLUDE "standard_metadata.map"
>         END
>     END
>     INCLUDE "outputformat_agg.map"
>     INCLUDE "legend.map"
>     LAYER
>         NAME "layer"
>         TYPE POINT
>         STATUS ON
>         INCLUDE "debug_layer.map" #2 Zeilen
>         DUMP TRUE
>         TOLERANCE 3
>         PROCESSING "CLOSE_CONNECTION=DEFER"
>         CONNECTIONTYPE OGR
>         CONNECTION
> "MYSQL:test,host=host,user=user,password=passwort,port=port,tables=tabelle"
> DATA "SELECT column1, column2 FROM tabelle" CLASS
>           STYLE
>             OUTLINECOLOR 100 100 100
>           END
>         END
>         METADATA
>             WMS_TITLE    "title"
>             WMS_TIMEEXTENT	"2011-10-13T00:00:00Z/2011-10-14T00:00:00Z"
>             WMS_TIMEITEM	"column1"
>   	    WMS_TIMEDEFAULT
> "2011-10-13T00:00:00Z"
>             WMS_ABSTRACT    "..."
>             INCLUDE "standard_extent.map"
>             LAYER_TITLE "..."
>             LAYER_DESC_STATUS "on"
>             LAYER_DESC "..."
>             gml_include_items "all"
>         END
>     END #LAYER
> END #MAP
> Hi,
> my humble suggestion is inline.
> I have done WMS Time successfully for PostGIS.
> Den 14.10.2011 13:55, skrev Katharina Sambs:
> > > Hi list,
> > > I would like to visualize spatial *mySQL* data through a wms-time
> > > service.
> > > *It is possible to visualize the data without the time
> > > parameters.* But as soon as I add the following parameters to the
> > > mapfile, my result contains only a white picture:
> > > LAYER
> > >    METADATA
> > >        WMS_TIMEEXTENT   "2010-01-10T00:00:00Z"
> > >        WMS_TIMEITEM   "column_name"
> > >        WMS_TIMEDEFAULT   "2010-01-10T00:00:00Z"
> > > There is no error message.
> > > *The same request works fine, while I use a shapefile as data
> > > source.*
> > > My second question:
> > > Shouldn't be there a 'where'-clause in the database selection,
> > > which contain the time parameter?
> I don't think so,
> > > Or works the wms-time like a Filter, which always ask all data
> > > from the database.
> > > Only in the second step, the data is filtered for the desired
> > > time?
> This filter should be added by Mapserver automagically when you have
> WMS_TIME* in METADATA field.
> > > Did anyone has an idea?
> You extent should maybe be more "wide".
>  From http://mapserver.org/ogc/wms_time.html
> /value/ - a single value. This is not directly supported in MapServer
> but there is an easy workwound by specifying the same value as min
> and max.
> I have always used extents similar to the example in the docs:
> "wms_timeextent"  "2004-01-01/2004-02-01"
> If this is not helping, you should attach (important parts of)
> mapfile and URL request.
> kind regards
> Jørn Vegard Røsnes
> > > The type of the time data in the mySQL database is "DATETIME".
> > > mysql.log
> > > 111014 13:27:45     4 Connect  user at server on database
> > >      4 Query DESCRIBE `table`
> > >      4 Query SELECT type, coord_dimension FROM geometry_columns
> > > WHERE f_table_name='table'
> > >      4 Query SELECT srid FROM geometry_columns WHERE f_table_name
> > > = 'table'
> > >      4 Query SELECT column1, column2 FROM table
> > >      4 Query SELECT type FROM geometry_columns WHERE
> > > f_table_name='table' 4 Query SELECT srid FROM geometry_columns
> > > WHERE f_table_name = 'table'
> > >      4 Quit
> > > mapserv.log:
> > > [Fri Oct  7 16:05:42 2011].982953 CGI Request 1 on process 18953
> > > [Fri Oct  7 16:05:42 2011].983461 msWMSLoadGetMapParams():
> > > enabling non-square pixels.
> > > [Fri Oct  7 16:05:42 2011].990638 msDrawMap(): kicking into
> > > non-square pixel preserving mode.
> > > [Fri Oct  7 16:05:42 2011].991160
> > > msOGRFileOpen(MYSQL:tabelle,host=host,user=user,password=passwort,port=port)...
> > > [Fri Oct  7 16:05:42 2011].991205
> > > OGROPen(MYSQL:tabelle,host=host,user=readonly,password=readonly,port=port)
> > > [Fri Oct  7 16:05:43 2011].20413
> > > msConnPoolRegister(layer,MYSQL:tabelle,host=host,user=readonly,password=passwort,port=port,0x5417290)
> > > [Fri Oct  7 16:05:43 2011].67656
> > > msOGRLayerClose(MYSQL:tabelle,host=host,user=readonly,password=passwort,port=port).
> > > [Fri Oct  7 16:05:43 2011].67662
> > > msOGRFileClose(MYSQL:tabelle,host=host,user=readonly,password=readonly,port=port,-1).
> > > [Fri Oct  7 16:05:43 2011].67672
> > > msConnPoolRelease(layer,MYSQL:tabelle,host=host,user=readonly,password=passwort,port=port,0x5417290)
> > > [Fri Oct  7 16:05:43 2011].67675
> > > msConnPoolClose(MYSQL:tabelle,host=host,user=readonly,password=passwort,port=port,0x5417290)
> > > [Fri Oct  7 16:05:43 2011].67849 msDrawMap(): Layer 2 (layer),
> > > 0.077s [Fri Oct  7 16:05:43 2011].67867 msDrawMap(): Drawing
> > > Label Cache, 0.000s [Fri Oct  7 16:05:43 2011].67871 msDrawMap()
> > > total time: 0.084s [Fri Oct  7 16:05:43 2011].170031
> > > msSaveImage() total time: 0.102s [Fri Oct  7 16:05:43
> > > 2011].170228 mapserv request processing time (msLoadMap not
> > > incl.): 0.187s [Fri Oct  7 16:05:43 2011].170234 msFreeMap():
> > > freeing map at 0x4f6cf30.
> > > getCapabilities:
> > > <Layer queryable="0" opaque="0" cascaded="0">
> > > <Name>layer</Name>
> > > <Title>title</Title>
> > > <Abstract>abstract</Abstract>
> > > <CRS>EPSG:4326</
> > > <EX_GeographicBoundingBox>
> > > <westBoundLongitude>5.18808</westBoundLongitude>
> > > <eastBoundLongitude>15</eastBoundLongitude>
> > > <southBoundLatitude>46.5582</southBoundLatitude>
> > > <northBoundLatitude>55.8653</northBoundLatitude>
> > > </EX_GeographicBoundingBox>
> > > <BoundingBox CRS="EPSG:4326" minx="46.5582" miny="5.18808"
> > > maxx="55.8653" maxy="15"/>
> > > <Dimension name="time" units="ISO8601"
> > > default="2010-01-10T00:00:00Z"
> > > nearestValue="0">2010-01-10T00:00:00Z</Dimension> </Layer>
> > > mysql version: 5.5.10-log
> > > MapServer version 5.6.5
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111017/52506a32/signature-0001.bin
