[mapserver-users] problem with MapServer as WMS client
Daniel Morissette dmorissette at mapgears.com
Mon Oct 17 08:33:08 EDT 2011
On 11-10-16 06:28 PM, Mr. Puneet Kishor wrote:
> On Oct 16, 2011, at 3:00 PM, Rahkonen Jukka wrote:
>> Including name of the remote mapfile into CONNECTION string is OK.
>> Perhaps addind DEBUG 5 into your WMS layer definition writes the request into log file but I do not know. Try and see if it helps.
> I did bump the DEBUG level to 5, but that doesn't show the WMS calls.
Is it possible that you set DEBUG 5 only at the map level in your test?
Setting DEBUG 5 inside the layer definition should log the HTTP requests.
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
