[mapserver-users] problem with MapServer as WMS client
Mr. Puneet Kishor
punk.kish at gmail.com
Sun Oct 16 18:28:12 EDT 2011
On Oct 16, 2011, at 3:00 PM, Rahkonen Jukka wrote:
> Hi,
> Have you tried to do it like it is suggested in the documentation http://mapserver.org/ogc/wms_client.html?
> LAYER
> NAME "country_bounds"
> TYPE RASTER
> STATUS ON
> CONNECTION "http://demo.mapserver.org/cgi-bin/wms?"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "country_bounds"
> "wms_server_version" "1.1.1"
> "wms_format" "image/gif"
> END
> END
> Thus no PROJECTION for the layer and only EPSG:4326 in wms_srs. EPSG:900913 must be included in the MAP level "wms_srs" but that should be enough.
That was it. Thanks.... no PROJECTION for the layer, and only EPSG:4326 in wms_srs. Additionally, I was too smart for my own good and had set the TYPE to POLYGON. I guess it should be RASTER because, from the perspective of MapServer, it is getting back an image, no?
> Including name of the remote mapfile into CONNECTION string is OK.
> Perhaps addind DEBUG 5 into your WMS layer definition writes the request into log file but I do not know. Try and see if it helps.
I did bump the DEBUG level to 5, but that doesn't show the WMS calls.
> At least you can run some local proxy like Fiddled and let it log the web traffic. In that case you will need to add wms_proxy_host and wms_proxy_port into layer metadata.
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Puneet Kishor [punk.kish at gmail.com] puolesta
> Lähetetty: 16. lokakuuta 2011 2:57
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] problem with MapServer as WMS client
> I am going from OpenLayers to MapServer acting as a WMS client to a remote server. OL is requesting SRS 900913, and the remote server is sending data in 4326, and I want to send it back to OL in 900913. My layer definition is like so
> LAYER
> NAME "foo"
> TYPE POLYGON
> STATUS ON
> CONNECTION "http://server/cgi-bin/mapserv?map=mapfile.map"
> CONNECTIONTYPE WMS
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> wms_srs "EPSG:900913 EPSG:4326"
> wms_name "foo"
> wms_server_version "1.1.1"
> wms_format "image/png"
> wms_enable_request "*"
> wms_extent "-180 -90 180 90"
> END
> END
> I am getting the following error
> msWMSLoadGetMapParams(): WMS server error. Invalid SRS given: SRS must be valid for all requested layers.
> I have three questions:
> 1. The docs at http://mapserver.org/ogc/wms_client.html state that the connection should not have any query params, but I don't see any options to pass the map file name. Is it ok the way I am doing it above?
> 2. How do I get around the above error?
> 3. Is there a way I can see the actual request that MapServer is making to the remote server, perhaps in the error.log?
> Puneet Kishor_______________________________________________
