[mapserver-users] Mapserver Projection Errors
SixDegrees paulcarlisle at comcast.net
Wed Oct 19 08:45:54 EDT 2011
I have a mapfile that contains several layers. Each layer has its own
projection, given in Proj.4 format, so the projection block looks like this:
   PROJECTION
      "+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs"
   END
or
   PROJECTION
      "+proj=utm +zone=39 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m
+no_defs"
   END
These seem to display properly when served directly to a web page, or when
loaded into QGis - in both cases as a WMS layer. But in the latter case, my
mapserver log fills up with the error message
   msProcessProjection(): Projection library error. projection not named
Access directly through the website, involving a Mapserver request for a WMS
layer, produces no errors.
What is causing this? And should I be worried about it?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapserver-Projection-Errors-tp6908527p6908527.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
