[mapserver-users] Re: Mapserver Projection Errors
SixDegrees paulcarlisle at comcast.net
Thu Oct 20 05:13:51 EDT 2011
That's what I'm trying to determine. Right now, I'm speculating that these
error messages are spurious, but I don't actually know if that's the case.
We are still using the application, so far without ill effect, but if this
is an indication that something is actually wrong I'd like to fix it.
Once we determine for certain that this is a spurious error, I'll certainly
file a bug report.
Rahkonen Jukka wrote:
> Hi,
> Have I understood right that your WMS service works fine for the users but
> you are getting one unnecessary line into the error log per each requested
> layer which has projection set with the Proj.4 strings? So it is mainly an
> annoyance and does not prevent any real work? I think also that using
> correct Proj.4 strings for the input projection is not an error. However,
> log write behaviour can not be cured by advice from the users and better
> place to visit next is http://trac.osgeo.org/mapserver/.  You have enough
> and exact information for filing a fine bug report.
> -Jukka Rahkonen-
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapserver-Projection-Errors-tp6908527p6912166.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
