[mapserver-users] MapServer x64 with Oracle x64
Richard Suematsu richard.suematsu at syncadd.com
Thu Oct 20 21:48:29 EDT 2011
I'm trying to use MapServer on a Windows 2k8 x64 server with 64-bit Oracle.  The MapServer I'm using was downloaded from Tamas (gisinternals).  MapServer crashes every time I run it.  Everything works fine when I publish from a shapefile.  But when I try to pull geometry out of Oracle, the exe crashes.  I'm using the plugin.
I checked the MapServer and Oracle dlls with dumpbin and everything is 64-bit.  I checked the mapserv.exe with DependancyWalker and everything looks ok.  Actually it flags IESHIM as a 32-bit but I don't think it's a problem.  The plugin is 64-bit.
I don't know what's wrong.  I've recreated this on a Win7 64-bit machine with the same issue, so it's consistent.  Anybody out there running MapServer with 64-bit Oracle?  Any ideas?
Thanks,
Rich
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the
intended recipient(s) and may contain confidential and privileged information. Unauthorized
review, use, disclosure or distribution is prohibited. If you are not the addressee indicated in this
message kindly notify the sender by reply e-mail and destroy all copies of the original message.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111020/8b340221/attachment.html
