[mapserver-users] MapServer x64 with Oracle x64
Smith, Michael ERDC-CRREL-NH Michael.Smith at usace.army.mil
Thu Oct 20 22:06:36 EDT 2011
Rich,
I think the oracle and sde plugins on gisinternals are only for the win32 mapserver packages. There is this note in the build information. Oracle x64 is only listed with GDAL/OGR, not with MapServer from the build information I looked at (http://vbkto.dyndns.org/sdk/PackageInfo.aspx?file=release-1600-x64-gdal-mapserver.zip)
Note: When using the Oracle and SDE plugins (Win32 packages only) be sure that the client libraries have been installed in the environment previously.
Mike
From: Richard Suematsu <richard.suematsu at syncadd.com<mailto:richard.suematsu at syncadd.com>>
Date: Thu, 20 Oct 2011 15:48:29 -1000
To: <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [mapserver-users] MapServer x64 with Oracle x64
I’m trying to use MapServer on a Windows 2k8 x64 server with 64-bit Oracle.  The MapServer I’m using was downloaded from Tamas (gisinternals).  MapServer crashes every time I run it.  Everything works fine when I publish from a shapefile.  But when I try to pull geometry out of Oracle, the exe crashes.  I’m using the plugin.
I checked the MapServer and Oracle dlls with dumpbin and everything is 64-bit.  I checked the mapserv.exe with DependancyWalker and everything looks ok.  Actually it flags IESHIM as a 32-bit but I don’t think it’s a problem.  The plugin is 64-bit.
I don’t know what’s wrong.  I’ve recreated this on a Win7 64-bit machine with the same issue, so it’s consistent.  Anybody out there running MapServer with 64-bit Oracle?  Any ideas?
Thanks,
Rich
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the
intended recipient(s) and may contain confidential and privileged information. Unauthorized
review, use, disclosure or distribution is prohibited. If you are not the addressee indicated in this
message kindly notify the sender by reply e-mail and destroy all copies of the original message.
_______________________________________________ mapserver-users mailing list mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111021/3e7cbf2f/attachment-0001.html
