[mapserver-users] MapServer x64 with Oracle x64
Tamas Szekeres szekerest at gmail.com
Fri Oct 21 08:24:28 EDT 2011
Mike,
As far as I remember both GDAL and MapServer contains the x64 versions of
the OCI plugins. I'll require to review the comments accordingly.
Best regards,
Tamas
2011/10/21 Smith, Michael ERDC-CRREL-NH <Michael.Smith at usace.army.mil>
>  Rich,
>  I think the oracle and sde plugins on gisinternals are only for the win32
> mapserver packages. There is this note in the build information. Oracle x64
> is only listed with GDAL/OGR, not with MapServer from the build information
> I looked at (
> http://vbkto.dyndns.org/sdk/PackageInfo.aspx?file=release-1600-x64-gdal-mapserver.zip
>   Note: When using the Oracle and SDE plugins (Win32 packages only) be
> sure that the client libraries have been installed in the environment
> previously.
>  Mike
>   From: Richard Suematsu <richard.suematsu at syncadd.com>
> Date: Thu, 20 Oct 2011 15:48:29 -1000
> To: <mapserver-users at lists.osgeo.org>
> Subject: [mapserver-users] MapServer x64 with Oracle x64
>   Hi,****
> I’m trying to use MapServer on a Windows 2k8 x64 server with 64-bit
> Oracle.  The MapServer I’m using was downloaded from Tamas (gisinternals).
> MapServer crashes every time I run it.  Everything works fine when I publish
> from a shapefile.  But when I try to pull geometry out of Oracle, the exe
> crashes.  I’m using the plugin.****
> I checked the MapServer and Oracle dlls with dumpbin and everything is
> 64-bit.  I checked the mapserv.exe with DependancyWalker and everything
> looks ok.  Actually it flags IESHIM as a 32-bit but I don’t think it’s a
> problem.  The plugin is 64-bit.****
> I don’t know what’s wrong.  I’ve recreated this on a Win7 64-bit machine
> with the same issue, so it’s consistent.  Anybody out there running
> MapServer with 64-bit Oracle?  Any ideas?****
> Thanks,****
> Rich****
> Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the
> intended recipient(s) and may contain confidential and privileged information. Unauthorized
> review, use, disclosure or distribution is prohibited. If you are not the addressee indicated in this
> message kindly notify the sender by reply e-mail and destroy all copies of the original message.
>  _______________________________________________ mapserver-users mailing
> list mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111021/a69a2c5f/attachment-0001.html
