[mapserver-users] MapServer x64 with Oracle x64
Tamas Szekeres szekerest at gmail.com
Fri Oct 21 08:19:34 EDT 2011
Richard,
You should try using the x64 version of instant client 11.1.0.7.0  (
http://www.oracle.com/technetwork/topics/winx64soft-089540.html) . This
version has been used to compile the plugin.
Best regards,
Tamas
2011/10/21 Richard Suematsu <richard.suematsu at syncadd.com>
> Hi,****
> I’m trying to use MapServer on a Windows 2k8 x64 server with 64-bit
> Oracle.  The MapServer I’m using was downloaded from Tamas (gisinternals).
> MapServer crashes every time I run it.  Everything works fine when I publish
> from a shapefile.  But when I try to pull geometry out of Oracle, the exe
> crashes.  I’m using the plugin.****
> I checked the MapServer and Oracle dlls with dumpbin and everything is
> 64-bit.  I checked the mapserv.exe with DependancyWalker and everything
> looks ok.  Actually it flags IESHIM as a 32-bit but I don’t think it’s a
> problem.  The plugin is 64-bit.****
> I don’t know what’s wrong.  I’ve recreated this on a Win7 64-bit machine
> with the same issue, so it’s consistent.  Anybody out there running
> MapServer with 64-bit Oracle?  Any ideas?****
> Thanks,****
> Rich****
> Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the
> intended recipient(s) and may contain confidential and privileged information. Unauthorized
> review, use, disclosure or distribution is prohibited. If you are not the addressee indicated in this
> message kindly notify the sender by reply e-mail and destroy all copies of the original message.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111021/bcc42f96/attachment.html
