[mapserver-users] MapServer x64 with Oracle x64
Richard Suematsu richard.suematsu at syncadd.com
Fri Oct 21 20:53:56 EDT 2011
Hi Tamas,
Ok, I tried InstantClient 11.1.0.7.0 on a Win2k8 64-bit box, but it still crashed.  This is what I get:
Problem signature:
  Problem Event Name: APPCRASH
  Application Name:         shp2img.exe
  Application Version:     0.0.0.0
  Application Timestamp:              4d3cb80b
  Fault Module Name:    OraOCIEI11.dll
  Fault Module Version: 0.0.0.0
  Fault Module Timestamp:          4908520f
  Exception Code:             c0000005
  Exception Offset:           000000000038e276
  OS Version:      6.0.6002.2.2.0.272.7
  Locale ID:           1033
  Additional Information 1:           e0e7
  Additional Information 2:           bbcb6956e86bbd347281120b794f7ee0
  Additional Information 3:           6510
  Additional Information 4:           c82eb6c8216192c6cd82879710a1f2e5
Sqlplus works.
Thanks,
Rich
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Friday, October 21, 2011 2:20 AM
To: Richard Suematsu
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] MapServer x64 with Oracle x64
Richard,
You should try using the x64 version of instant client 11.1.0.7.0  (http://www.oracle.com/technetwork/topics/winx64soft-089540.html) . This version has been used to compile the plugin.
Best regards,
Tamas
2011/10/21 Richard Suematsu <richard.suematsu at syncadd.com>
I’m trying to use MapServer on a Windows 2k8 x64 server with 64-bit Oracle.  The MapServer I’m using was downloaded from Tamas (gisinternals).  MapServer crashes every time I run it.  Everything works fine when I publish from a shapefile.  But when I try to pull geometry out of Oracle, the exe crashes.  I’m using the plugin.
I checked the MapServer and Oracle dlls with dumpbin and everything is 64-bit.  I checked the mapserv.exe with DependancyWalker and everything looks ok.  Actually it flags IESHIM as a 32-bit but I don’t think it’s a problem.  The plugin is 64-bit.
I don’t know what’s wrong.  I’ve recreated this on a Win7 64-bit machine with the same issue, so it’s consistent.  Anybody out there running MapServer with 64-bit Oracle?  Any ideas?
Thanks,
Rich
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the
intended recipient(s) and may contain confidential and privileged information. Unauthorized
review, use, disclosure or distribution is prohibited. If you are not the addressee indicated in this
message kindly notify the sender by reply e-mail and destroy all copies of the original message.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111021/e802585e/attachment-0001.html
