[mapserver-users] MapServer x64 with Oracle x64
Richard Suematsu
richard.suematsu at syncadd.com
Sat Oct 22 06:16:12 EDT 2011
Ok, I compiled MapServer with 64-bit Oracle (11gR2) and it seems to be working.
Tamas and Mike, thanks for your help.
Richard Suematsu - Systems / Development Manager
Syncadd Systems, Inc.
Tel: (808) 941-8286
Fax: (808) 941-7173
Website: www.syncadd.com
----- Original Message -----
[mailto:szekerest at gmail.com]
To: Richard Suematsu
[mailto:richard.suematsu at syncadd.com]
Cc:
mapserver-users at lists.osgeo.org
Sent: Fri, 21 Oct 2011 02:19:34
-1000
Subject: Re: [mapserver-users] MapServer x64 with Oracle x64
> Richard,
> You should try using the x64 version of instant client 11.1.0.7.0 (
> http://www.oracle.com/technetwork/topics/winx64soft-089540.html) . This
> version has been used to compile the plugin.
> Best regards,
> Tamas
> 2011/10/21 Richard Suematsu <richard.suematsu at syncadd.com>
> > Hi,****
> > I’m trying to use MapServer on a Windows 2k8 x64 server with 64-bit
> > Oracle. The MapServer I’m using was downloaded from Tamas
> (gisinternals).
> > MapServer crashes every time I run it. Everything works fine when I
> publish
> > from a shapefile. But when I try to pull geometry out of Oracle, the exe
> > crashes. I’m using the plugin.****
> > I checked the MapServer and Oracle dlls with dumpbin and everything is
> > 64-bit. I checked the mapserv.exe with DependancyWalker and everything
> > looks ok. Actually it flags IESHIM as a 32-bit but I don’t think it’s
> a
> > problem. The plugin is 64-bit.****
> > I don’t know what’s wrong. I’ve recreated this on a Win7 64-bit
> machine
> > with the same issue, so it’s consistent. Anybody out there running
> > MapServer with 64-bit Oracle? Any ideas?****
> > Thanks,****
> > Rich****
> > Confidentiality Notice: This e-mail message, including any attachments, is
> for the sole use of the
> > intended recipient(s) and may contain confidential and privileged
> information. Unauthorized
> > review, use, disclosure or distribution is prohibited. If you are not the
> addressee indicated in this
> > message kindly notify the sender by reply e-mail and destroy all copies of
> the original message.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of the
intended recipient(s) and may contain confidential and privileged information. Unauthorized
review, use, disclosure or distribution is prohibited. If you are not the addressee indicated in this
message kindly notify the sender by reply e-mail and destroy all copies of the original message.
