AW: AW: [mapserver-users] Mapserver Projection Errors
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Fri Oct 21 05:35:05 EDT 2011
I fear that the last thing that I can say is that I do not get any errors into my error log with CONFIG "PROJ_DEBUG" "ON"
if I do the change from init=epsg into +proj. WMS continues to work in a pretty similar way. I am running Mapserver 6.0.0 (MS4W).
 #PROJECTION
 #  "init=epsg:4326"
 #END
 PROJECTION
 "+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs"
 END
There is something that you can still make for simplifying your case. Use tiff instead of .vrt as an input and remove the layer extent and wms_extent.
-Jukka Rahkonen-
SixDegrees wrote:
> FWIW, here's a stripped-down mapfile with a single layer that
> produces the
> error. Note that I have changed the explicit IP addresses to
> 'localhost' and
> I have changed anything referring to the image name to
> "test_image" for
> proprietary reasons, but everything else remains the same as in our
> production environment:
> MAP
> NAME "Test_Images"
> STATUS ON
> SIZE 400 300
> EXTENT -180 -90 180 90
> UNITS DD
> SHAPEPATH "../../../data/test_data/"
> IMAGECOLOR 255 255 255
> IMAGETYPE png24
> CONFIG "MS_ERRORFILE" "/var/log/mapserver/mapserver_error.log"
> DEBUG 5
> CONFIG "CPL_DEBUG" "ON" # Debug GDAL calls
> CONFIG "PROJ_DEBUG" "ON" # Debug PROJ calls
> WEB
>   IMAGEPATH "/ms4w/tmp/ms_tmp/"
>   IMAGEURL "/ms_tmp/"
>   METADATA
>     "wfs_title"     "Test_Images"
>     "wfs_onlineresource"
> "http://localhost/cgi-bin/mapserv?map=images_template_test.map&"
>     "wms_title"     "Test_Images"
>     "wms_onlineresource"
>     "wms_srs"       "EPSG:4326"
>     "ows_enable_request" "*"
>   END
> END
> PROJECTION
>   "init=epsg:4326"
> END
> # Start of layer definitions
> LAYER
>    NAME "test_image"
>    EXTENT 51.44325 35.71925 51.64125 35.87325
>    METADATA
>       "wms_title" "test_image"
>       "wms_extent" "51.44325 35.71925 51.64125 35.87325"
>    END
>    PROCESSING "SCALE=AUTO"
>    PROCESSING "SCALE_BUCKETS=256"
>    TYPE RASTER
>    DATA "/data/geodata/yongbyon/test_image.vrt"
>    PROJECTION
>    END
> END
> END # Map File
> http://osgeo-org.1803224.n2.nabble.com/Mapserver-Projection-Er
rors-tp6908527p6916268.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
