[mapserver-users] Sporadically "Cannot create OCI handlers"
Meine Toonen
meinetoonen at b3partners.nl
Tue Oct 25 08:00:50 EDT 2011
Hi list,
I have a layer defined in a mapfile, using an oracle connection. Most of the time this works, but sometimes I get an error.
The Error:
msDrawMap(): Image handling error. Failed to draw layer named 'telvakken_l'.; msOracleSpatialLayerOpen(): OracleSpatial error. Cannot create OCI Handlers. Connection failed. Check the connection string.
Seems to me the connection string is fine, because it does work. Maybe you can help me? The layer is defined below:
The Mapfile:
LAYER NAME "telvakken_l" DATA "SHAPE from (select OBJECTID,TELPUNT,NAAM_WEGVA,BEHEERDER,BEGIN_HMP,EIND_HMP,WEGN,SHAPE from telvakken_l) using UNIQUE OBJECTID SRID 90112" TYPE LINE CONNECTIONTYPE oraclespatial CONNECTION "UN/PW at DB" PROCESSING "CLOSE_CONNECTION=DEFER" METADATA ows_title "Verkeerstelvakken" ows_extent "150000 296000 223454 435000" ows_abstract "Verkeerstelvakken" gml_include_items "all" gml_featureid "OBJECTID" ows_metadataurl_format "text/xml" ows_metadataurl_href "http://acceptatie.prvlimburg.nl/mapfiles/infrastructuur/metadata/telvakken_l.xml" ows_metadataurl_type "FGDC" END #METADATA DUMP TRUE OPACITY 85 STATUS on UNITS METERS TEMPLATE "/var/www/html/blank.html" SIZEUNITS PIXELS MINSCALEDENOM 0 MAXSCALEDENOM 10000000 TOLERANCE 3 TOLERANCEUNITS PIXELS PROJECTION "init=epsg:28992" END #PROJECTION CLASS NAME 'Verkeerstelvakken' STYLE WIDTH 2 COLOR 255 31 0 END #STYLE END #CLASS END #LAYER
Thanks in advance.
Kind regards,
Meine Toonen
B3Partners BV
Tel: 030 214 2083
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111025/078c7194/attachment.html
