[mapserver-users] tileindex shptree
Fri Oct 28 17:31:03 EDT 2011
Eric,
Do things fail consistently fora  given request?  I would be
willing to do some examination of this problem this evening
(pacific time) if you can provide a canned demonstration of
the issue (mapfile+tileindex+query).  I should be able to fake
the data referred to by the tileindex if necessary.
I don't feel that adding a spatial index (.qix) is the right
solution.   Something is either wrong with your tileindex
or with mapserver (IMHO).
Best regards,
On Fri, Oct 28, 2011 at 2:09 PM, Eric Weisbender <Weisbend at wapa.gov> wrote:
> Hello,
> We are using a tileindex layer to draw multiple county parcel data layers.
> For some reason the query of these layers is either hit or miss.  Sometimes
> it returns a query.  Other times a query returns "Invalid field index 0"
> from the error file defined in the mapfile.  And the third query result I'm
> getting is "Internal Server Error" from I assume apache.  These results are
> all on the same data indexed by this one tileindex layer.  Would it help if
> I built a shptree qix file and do I just do that for the tileindex file or
> all file the tileindex file is pointing to.  I have wasted two day's on this
> and am completely open to any and all idea's.  Thanks in advance.
> EW
> mapserver-users at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
