[mapserver-users] Re: Problems with Mapserver as WMS service (jpeg)
Chrishelring christianhelring at gmail.com
Sun Oct 30 11:16:20 EDT 2011
below is a snipped part of the map file. I´ve removed the layers that is
working but kept the one which is not (the orto2011 layer). If you need the
complete map file I´ll send it.
The layer is a ECW raster file (complete mosaiced ECW of the municipality
i´m working in). When I try to use the WMS service in ArcGIS og Mapinfo the
layer is just showing "white" / nothing.
The map-file is auto-generated in our webgis solution.
map
name ''
status ON
size 830 475
projection
 "init=epsg:25832"
end
shapepath
'E:\spatialsuite\sites\test-webgis\appbase\wwwroot\WEB-INF\data\shp'
units meters
maxsize 10000
extent 713000 6173000 720000 6180000
fontset
'E:\spatialsuite\sites\test-webgis\appbase\wwwroot\WEB-INF\resources/fonts/fontset.txt'
symbolset
'E:\spatialsuite\sites\test-webgis\appbase\wwwroot\WEB-INF\resources/symbols/symbols3_5.txt'
imagecolor 255 255 255
datapattern '.*'
templatepattern '.*'
imagetype png24
outputformat
  name 'jpeg24'
  mimetype "image/jpeg"
  driver "agg/JPEG"
  imagemode RGB
  extension "jpeg"
  formatoption "QUALITY=80 INTERLACE=ON"
end
outputformat
  name 'jpeg24_gd'
  mimetype "image/jpg"
  driver "GD/JPEG"
  imagemode RGB
  extension "jpg"
  formatoption "QUALITY=90"
end
outputformat
  name 'png24'
  mimetype "image/png"
  driver "AGG/PNG"
  imagemode RGB
  extension "png"
end
outputformat
  name 'gif'
  mimetype "image/gif"
  driver "GD/GIF"
  imagemode PC256
  extension "gif"
  transparent ON
end
outputformat
  name 'imagemap'
  mimetype "text/html"
  driver imagemap
end
web
  template
'E:\spatialsuite\sites\test-webgis\appbase\wwwroot\WEB-INF\tmp/mapserver.html'
  minscale 100
  imagepath 'E:\spatialsuite\sites\test-webgis\appbase\wwwroot\tmp\'
  log
'E:\spatialsuite\sites\test-webgis\appbase\wwwroot\WEB-INF\log\mapserver.log'
  empty '[cbinfo.emptypage]'
  metadata
 "wms_title"  "Rødovre Kommunes WMS service - Test"
           "wms_onlineresource"
"http://test-webgis:9180/wms?servicename=rk-wms&"
           "wms_srs" "epsg:32632 epsg:23032 epsg:25832"
           "wms_feature_info_mime_type" "text/xml"
           "wms_server_version" "1.1.1"
           "wms_extent" "713000 6173000 720000 6180000"
  end
end
querymap
  status ON
  style SELECTED
end
legend
  status OFF
  keysize 15 10
  position ul
  label
    type TRUETYPE
    antialias true
    font arial
    size 8
    color 0 0 0
  end
end
reference
  status OFF
  size 140 96
 #            <extent>708960.416667 6167500.000000 720189.583333
6175200.000000</extent>
  color -1 -1 -1
  outlinecolor 210 136 0
'E:\spatialsuite\sites\test-webgis\appbase\wwwroot/images/custom/test/oversigt1.gif'
end
scalebar
  status OFF
  label
    type BITMAP
    outlinecolor 255 255 255
    size medium
    color 0 0 0
  end
  size 200 5
  color 255 255 255
  backgroundcolor 0 0 0
  outlinecolor 0 0 0
  intervals 5
  position ll
  transparent false
  units meters
end
 #Imported from
E:\spatialsuite\sites\test-webgis\appbase\wwwroot\WEB-INF\config\themes\custom\theme-orto-2011-gwc.xml
layer
  name 'orto2011'
  status off
  type RASTER
  class
    name 'Luftfoto 2011'
  end
  data 'E:\spatialsuite\data\ortofoto\orto2011\Kommune\Rodovre_2011.ecw'
  transparency 100
  metadata
"wms_title" "orto2011"
"wms_group_title" "orto2011"
"wms_srs" "EPSG:25832"
  end
  group 'theme-orto-2011-gwc'
  projection
 "init=EPSG:25832"
  end
end
end
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-Mapserver-as-WMS-service-jpeg-tp6941932p6945688.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
