[mapserver-users] Problem compiling MapServer 6.0.1 with libpng
Dejan Gambin
dejan.gambin at coin.hr
Mon Sep 12 05:41:40 EDT 2011
It doesn't help :-(
Here is the part of make compile statement with mapimageio.c, maybe this can help you:
gcc -c -g -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT -DNEED_STRRSTR -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_LIBXML2 -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH -DUSE_KML -DUSE_WFS_SVR -DUSE_WMS_SVR -DUSE_MYSQL -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION -DUSE_GDAL -DUSE_OGR -DUSE_PROJ -DUSE_AGG_SVG_SYMBOLS -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DGD_HAS_GET_TRUE_COLOR_PIXEL -DUSE_ICONV -DUSE_GIF -DUSE_PNG -DUSE_ZLIB -DUSE_FREETYPE -DDISABLE_CVSID -I/usr/include/freetype2 -I/usr/local/include -I/usr/include -Irenderers/agg/include -I/usr/include -I/usr/local/include -I/usr/include/postgresql -I/usr/include/mysql -DBIG_JOINS=1 -fPIC -I/usr/include -I/usr/include/libxml2 mapimageio.c -o mapimageio.o
regards, dejan
BTW, I don't have 1.4 installed, just 1.5.4. And system libpng in /usr/lib
On 12. ruj. 2011., at 11:17, thomas bonfort wrote:
> can you try modifying mapimageio.c and replace
> #include <png.h>
> by
> #include "/usr/local/include/png.h"
> if you have both png 1.4 and 1.5 in /usr/local, you're asking for
> trouble, make sure this is not the case
> 2011/9/12 Dejan Gambin <dejan.gambin at coin.hr>:
>> Hi Thomas
>> Thanks for the help. As I said, I have system libpng installed in /usr/lib:
>> dgambin at coin:~/mapserver-6.0.1$ dpkg -l libpng*
>> Desired=Unknown/Install/Remove/Purge/Hold
>> | Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
>> |/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
>> ||/ Name Version Description
>> un libpng-dev <none> (no description available)
>> ii libpng12-0 1.2.27-2+lenny PNG library - runtime
>> un libpng12-0-dev <none> (no description available)
>> ii libpng12-dev 1.2.27-2+lenny PNG library - development
>> un libpng2 <none> (no description available)
>> un libpng2-dev <none> (no description available)
>> un libpng3-dev <none> (no description available)
>> dgambin at coin:~/mapserver-6.0.1$ ls -l /usr/lib/libpng*
>> -rw-r--r-- 1 root root 243004 2011-07-25 00:16 /usr/lib/libpng12.a
>> lrwxrwxrwx 1 root root 18 2011-09-09 13:29 /usr/lib/libpng12.so -> libpng12.so.0.27.0
>> lrwxrwxrwx 1 root root 18 2011-08-08 20:07 /usr/lib/libpng12.so.0 -> libpng12.so.0.27.0
>> -rw-r--r-- 1 root root 153224 2011-07-25 00:15 /usr/lib/libpng12.so.0.27.0
>> lrwxrwxrwx 1 root root 10 2011-09-09 13:29 /usr/lib/libpng.a -> libpng12.a
>> lrwxrwxrwx 1 root root 11 2011-09-09 13:29 /usr/lib/libpng.so -> libpng12.so
>> And I have libpng-1.5.4 installed in /usr/local/lib:
>> dgambin at coin:~/mapserver-6.0.1$ ls -l /usr/local/lib/libpng*
>> -rw-r--r-- 1 root staff 1051610 2011-09-09 13:09 /usr/local/lib/libpng15.a
>> -rwxr-xr-x 1 root staff 934 2011-09-09 13:09 /usr/local/lib/libpng15.la
>> lrwxrwxrwx 1 root staff 18 2011-09-09 13:09 /usr/local/lib/libpng15.so -> libpng15.so.15.4.0
>> lrwxrwxrwx 1 root staff 18 2011-09-09 13:09 /usr/local/lib/libpng15.so.15 -> libpng15.so.15.5.0
>> -rwxr-xr-x 1 root staff 597897 2011-09-09 13:09 /usr/local/lib/libpng15.so.15.4.0
>> lrwxrwxrwx 1 root staff 10 2011-09-09 13:09 /usr/local/lib/libpng.a -> libpng15.a
>> lrwxrwxrwx 1 root staff 11 2011-09-09 13:09 /usr/local/lib/libpng.la -> libpng15.la
>> lrwxrwxrwx 1 root staff 11 2011-09-09 13:09 /usr/local/lib/libpng.so -> libpng15.so
>> I made configure with --with-png=/usr/local
>> Make fails in this:
>> dgambin at coin:~/mapserver-6.0.1$ make
>> g++ -g -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT -DNEED_STRRSTR -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_LIBXML2 -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH -DUSE_KML -DUSE_WFS_SVR -DUSE_WMS_SVR -DUSE_MYSQL -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION -DUSE_GDAL -DUSE_OGR -DUSE_PROJ -DUSE_AGG_SVG_SYMBOLS -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DGD_HAS_GET_TRUE_COLOR_PIXEL -DUSE_ICONV -DUSE_GIF -DUSE_PNG -DUSE_ZLIB -DUSE_FREETYPE -DDISABLE_CVSID -I/usr/include/freetype2 -I/usr/local//include -I/usr/include -Irenderers/agg/include -I/usr/include -I/usr/local/include -I/usr/include/postgresql -I/usr/include/mysql -DBIG_JOINS=1 -fPIC -I/usr/include -I/usr/include/libxml2 shp2img.o -L. -lmapserver -lfreetype -lz -lgd -L/usr/lib64 -lgd -ljpeg -lfreetype -lz -L/usr/local//lib -lpng -lz -lXpm -lX11 -lexpat -L/usr/lib64 -lproj -ljpeg -L/usr/local//lib -lpng -lgif -L/usr/local/lib -lgdal -L/usr/lib -lpq -L/usr/lib/mysql -lmysqlclient -lmysqlclient -lcurl -L/usr/lib -lc -lz -lxml2 -lm -lstdc++ -o shp2img
>> ./libmapserver.a(mapimageio.o): In function `savePalettePNG':
>> /home/dgambin/mapserver-6.0.1/mapimageio.c:274: undefined reference to `png_set_longjmp_fn'
>> ./libmapserver.a(mapimageio.o): In function `saveAsPNG':
>> /home/dgambin/mapserver-6.0.1/mapimageio.c:461: undefined reference to `png_set_longjmp_fn'
>> ./libmapserver.a(mapimageio.o): In function `readPNG':
>> /home/dgambin/mapserver-6.0.1/mapimageio.c:738: undefined reference to `png_set_longjmp_fn'
>> collect2: ld returned 1 exit status
>> Is there anything wrong here? I'll send you anything else if needed :-)
>> Thanks very much
>> regards, dejan
>> On 12. ruj. 2011., at 10:31, thomas bonfort wrote:
>>> Can you check you are linking against the same version libpng library
>>> as the png.h header (i.e. check you don't have multiple png versions
>>> installed)
>>>> Hi,
>>>> I am still unable to compiče mapserver 6.0.1. I can't find this function (png_set_longjmpfn) defined anywhere. Can someone give me a clue? I am almost sure I am doing some stupid mistake, but for me seems unsolvable :-(
>>>> Thanks very much
>>>> regards, dejan
>>>> On 8. ruj. 2011., at 12:12, Dejan Gambin wrote:
>>>>> Hi,
>>>>> After many trials and missings, I am still unable to compile MapServer 6.0.1 (6.0.0 also) on my Debian Lenny machine.
>>>>> Here is the error I get:
>>>>> Here is my configure:
>>>>> ./configure --with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gda
>>>>> l-config --with-wfs --with-wfsclient --with-wmsclient --enable-debug --with-curl
>>>>> -config=/usr/bin/curl-config --with-proj=/usr --with-jpeg --with-freetype=/usr/b
>>>>> in/ --with-postgis=/usr/bin/pg_config --with-mysql=/usr/bin/mysql_config --with-
>>>>> libiconv=/usr --with-kml=yes --with-php=/usr/include/php5 --with-png=/usr/local
>>>>> Since I have system libpng 1.2.27-2, I downloaded and installed 1.5.4 and put "--with-png=/usr/local" in my configure file. But seems like it doesn't help. I also tried with 1.4.8. Stiil the same issue. Also tried without "--with-png=/usr/local" (so it should use system libpng)...nothing
>>>>> I have compiled using newest gdal 1.8.1. GDAL compiled ok with libpng 1.5.4.
>>>>> Am I doing something wrong?
>>>>> Thank you very much for any useful info
>>>>> regards, dejan_______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
