[mapserver-users] Problem compiling MapServer 6.0.1 with libpng
thomas bonfort thomas.bonfort at gmail.com
Mon Sep 12 05:45:27 EDT 2011
2011/9/12 Dejan Gambin <dejan.gambin at coin.hr>:
> It doesn't help :-(
> Here is the part of make compile statement with mapimageio.c, maybe this can help you:
> gcc -c -g  -fPIC -Wall     -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT -DNEED_STRRSTR           -DUSE_WMS_LYR -DUSE_WFS_LYR  -DUSE_LIBXML2 -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH -DUSE_KML  -DUSE_WFS_SVR -DUSE_WMS_SVR  -DUSE_MYSQL -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION -DUSE_GDAL -DUSE_OGR   -DUSE_PROJ -DUSE_AGG_SVG_SYMBOLS    -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DGD_HAS_GET_TRUE_COLOR_PIXEL -DUSE_ICONV -DUSE_GIF -DUSE_PNG -DUSE_ZLIB -DUSE_FREETYPE   -DDISABLE_CVSID -I/usr/include/freetype2  -I/usr/local/include   -I/usr/include -Irenderers/agg/include    -I/usr/include   -I/usr/local/include -I/usr/include/postgresql -I/usr/include/mysql  -DBIG_JOINS=1 -fPIC    -I/usr/include   -I/usr/include/libxml2   mapimageio.c -o mapimageio.o
> regards, dejan
> BTW, I don't have 1.4 installed, just 1.5.4. And system libpng in /usr/lib
as you had stated you tried with 1.4 I just wanted to make sure.
ok, last step before opening a ticket:
- revert mapimageio.c to its original state
- check the output of
-I/usr/include   -I/usr/include/libxml2   mapimageio.c -M
for the location of png.h
- if png.h comes from /usr/local/include, open a ticket and assign it to me
> On 12. ruj. 2011., at 11:17, thomas bonfort wrote:
>> can you try modifying mapimageio.c and replace
>> #include <png.h>
>> by
>> #include "/usr/local/include/png.h"
>> if you have both png 1.4 and 1.5 in /usr/local, you're asking for
>> trouble, make sure this is not the case
>>> Hi Thomas
>>> Thanks for the help. As I said, I have system libpng installed in /usr/lib:
>>> dgambin at coin:~/mapserver-6.0.1$ dpkg -l libpng*
>>> Desired=Unknown/Install/Remove/Purge/Hold
>>> | Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
>>> |/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
>>> ||/ Name           Version        Description
>>> un  libpng-dev     <none>         (no description available)
>>> ii  libpng12-0     1.2.27-2+lenny PNG library - runtime
>>> un  libpng12-0-dev <none>         (no description available)
>>> ii  libpng12-dev   1.2.27-2+lenny PNG library - development
>>> un  libpng2        <none>         (no description available)
>>> un  libpng2-dev    <none>         (no description available)
>>> un  libpng3-dev    <none>         (no description available)
>>> dgambin at coin:~/mapserver-6.0.1$ ls -l /usr/lib/libpng*
>>> -rw-r--r-- 1 root root 243004 2011-07-25 00:16 /usr/lib/libpng12.a
>>> lrwxrwxrwx 1 root root     18 2011-09-09 13:29 /usr/lib/libpng12.so -> libpng12.so.0.27.0
>>> lrwxrwxrwx 1 root root     18 2011-08-08 20:07 /usr/lib/libpng12.so.0 -> libpng12.so.0.27.0
>>> -rw-r--r-- 1 root root 153224 2011-07-25 00:15 /usr/lib/libpng12.so.0.27.0
>>> lrwxrwxrwx 1 root root     10 2011-09-09 13:29 /usr/lib/libpng.a -> libpng12.a
>>> lrwxrwxrwx 1 root root     11 2011-09-09 13:29 /usr/lib/libpng.so -> libpng12.so
>>> And I have libpng-1.5.4 installed in /usr/local/lib:
>>> dgambin at coin:~/mapserver-6.0.1$ ls -l /usr/local/lib/libpng*
>>> -rw-r--r-- 1 root staff 1051610 2011-09-09 13:09 /usr/local/lib/libpng15.a
>>> -rwxr-xr-x 1 root staff     934 2011-09-09 13:09 /usr/local/lib/libpng15.la
>>> lrwxrwxrwx 1 root staff      18 2011-09-09 13:09 /usr/local/lib/libpng15.so -> libpng15.so.15.4.0
>>> lrwxrwxrwx 1 root staff      18 2011-09-09 13:09 /usr/local/lib/libpng15.so.15 -> libpng15.so.15.5.0
>>> -rwxr-xr-x 1 root staff  597897 2011-09-09 13:09 /usr/local/lib/libpng15.so.15.4.0
>>> lrwxrwxrwx 1 root staff      10 2011-09-09 13:09 /usr/local/lib/libpng.a -> libpng15.a
>>> lrwxrwxrwx 1 root staff      11 2011-09-09 13:09 /usr/local/lib/libpng.la -> libpng15.la
>>> lrwxrwxrwx 1 root staff      11 2011-09-09 13:09 /usr/local/lib/libpng.so -> libpng15.so
>>> I made configure with --with-png=/usr/local
>>> Make fails in this:
>>> dgambin at coin:~/mapserver-6.0.1$ make
>>> g++ -g  -fPIC -Wall     -DHAVE_VSNPRINTF -DNEED_STRLCPY -DNEED_STRLCAT -DNEED_STRRSTR           -DUSE_WMS_LYR -DUSE_WFS_LYR  -DUSE_LIBXML2 -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH -DUSE_KML  -DUSE_WFS_SVR -DUSE_WMS_SVR  -DUSE_MYSQL -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION -DUSE_GDAL -DUSE_OGR   -DUSE_PROJ -DUSE_AGG_SVG_SYMBOLS    -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DGD_HAS_GET_TRUE_COLOR_PIXEL -DUSE_ICONV -DUSE_GIF -DUSE_PNG -DUSE_ZLIB -DUSE_FREETYPE   -DDISABLE_CVSID -I/usr/include/freetype2  -I/usr/local//include   -I/usr/include -Irenderers/agg/include    -I/usr/include   -I/usr/local/include -I/usr/include/postgresql -I/usr/include/mysql  -DBIG_JOINS=1 -fPIC    -I/usr/include   -I/usr/include/libxml2   shp2img.o  -L. -lmapserver -lfreetype -lz -lgd -L/usr/lib64 -lgd -ljpeg -lfreetype -lz -L/usr/local//lib -lpng -lz -lXpm -lX11  -lexpat   -L/usr/lib64 -lproj -ljpeg -L/usr/local//lib -lpng -lgif  -L/usr/local/lib -lgdal -L/usr/lib -lpq -L/usr/lib/mysql -lmysqlclient -lmysqlclient -lcurl    -L/usr/lib -lc    -lz -lxml2  -lm -lstdc++    -o shp2img
>>> ./libmapserver.a(mapimageio.o): In function `savePalettePNG':
>>> /home/dgambin/mapserver-6.0.1/mapimageio.c:274: undefined reference to `png_set_longjmp_fn'
>>> ./libmapserver.a(mapimageio.o): In function `saveAsPNG':
>>> /home/dgambin/mapserver-6.0.1/mapimageio.c:461: undefined reference to `png_set_longjmp_fn'
>>> ./libmapserver.a(mapimageio.o): In function `readPNG':
>>> /home/dgambin/mapserver-6.0.1/mapimageio.c:738: undefined reference to `png_set_longjmp_fn'
>>> collect2: ld returned 1 exit status
>>> Is there anything wrong here? I'll send you anything else if needed :-)
>>> Thanks very much
>>> regards, dejan
>>> On 12. ruj. 2011., at 10:31, thomas bonfort wrote:
>>>> Can you check you are linking against the same version libpng library
>>>> as the png.h header (i.e. check you don't have multiple png versions
>>>> installed)
>>>>> Hi,
>>>>> I am still unable to compiče mapserver 6.0.1. I can't find this function (png_set_longjmpfn) defined anywhere. Can someone give me a clue? I am almost sure I am doing some stupid mistake, but for me seems unsolvable :-(
>>>>> Thanks very much
>>>>> regards, dejan
>>>>> On 8. ruj. 2011., at 12:12, Dejan Gambin wrote:
>>>>>> Hi,
>>>>>> After many trials and missings, I am still unable to compile MapServer 6.0.1 (6.0.0 also) on my Debian Lenny machine.
>>>>>> Here is the error I get:
>>>>>> Here is my configure:
>>>>>> ./configure --with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gda
>>>>>> l-config --with-wfs --with-wfsclient --with-wmsclient --enable-debug --with-curl
>>>>>> -config=/usr/bin/curl-config --with-proj=/usr --with-jpeg --with-freetype=/usr/b
>>>>>> in/ --with-postgis=/usr/bin/pg_config --with-mysql=/usr/bin/mysql_config --with-
>>>>>> libiconv=/usr --with-kml=yes --with-php=/usr/include/php5 --with-png=/usr/local
>>>>>> Since I have system libpng 1.2.27-2, I downloaded and installed 1.5.4 and put "--with-png=/usr/local" in my configure file. But seems like it doesn't help. I also tried with 1.4.8. Stiil the same issue. Also tried without "--with-png=/usr/local" (so it should use system libpng)...nothing
>>>>>> I have compiled using newest gdal 1.8.1. GDAL compiled ok with libpng 1.5.4.
>>>>>> Am I doing something wrong?
>>>>>> Thank you very much for any useful info
>>>>>> regards, dejan_______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
