[mapserver-users] RE: mapserver 6.0.1 and cairo SVG
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Wed Sep 14 13:23:25 EDT 2011
This requests shows me a map on a browser:
http://188.64.1.61/cgi-bin/ms_ows?&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1059&HEIGHT=653&LAYERS=borders&TRANSPARENT=TRUE&FORMAT=image%2Fsvg%2Bxml&BBOX=2189023.591117917,6540740.0,4199096.408882082,7780190.0&SRS=EPSG:2393&STYLES=
I do not have a template set anywhere in the corresponding mapfile. Doesn't a request like this work for you?
-Jukka Rahkonen-
Raivo Alla wrote:
> Thanks!
> A step forward!
> This way it suggest me to declare TEMPLATE in the WEB section. Hence the question: how should I put this SVG output file in html template?
> SVG file itself was generated in TMP folder, filename contains randomly generated numbers...
> I would like the browser to display the SVG output on the run.
Thanks again,
Raivo
Works as an url encoded format=image%2Fsvg%2Bxml from browser.
I do not know if this is how it should be, though.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org<http://lists.osgeo.org> [mapserver-users-bounces at lists.osgeo.org<http://lists.osgeo.org>] käyttäjän Raivo Alla [snaperski at gmail.com<http://gmail.com>] puolesta
Lähetetty: 14. syyskuuta 2011 9:47
Vastaanottaja: mapserver-users at lists.osgeo.org<http://lists.osgeo.org>
Aihe: [mapserver-users] mapserver 6.0.1 and cairo SVG
Hello!
Friends, I have some issues with getting SVG output working here...
I have latest MS4W install:
MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I don't see  OUTPUT=SVG there, but I guess its normal, since this MS version has non-native (Cairo) SVG support.
Well, but even if I have configured in my mapfile the outputformat like that:
IMAGETYPE svg
OUTPUTFORMAT
 NAME "svg"
 DRIVER CAIRO/SVG
 MIMETYPE "image/svg+xml"
 IMAGEMODE RGB
 EXTENSION "svg"
END
...and get correct GetCapabilities request, where SVG format is listed as first, then I still cant see SVG format listed when
using ArcMap as WMS-client (there are PNG24, JPEG and PNG8 listed though).
Also when I send GetMap request (setting FORMAT=image/svg+xml) through browser, I get response:
msWMSLoadGetMapParams(): Image handling error. Unsupported output format (image/svg xml).
Where should I dig into?
Thank you in advance,
Raivo Alla,
Estonia
