Re: Σχετ: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Thu Sep 22 09:57:02 EDT 2011
I turned PostgreSQL statement logging on and I can see this line to appear:
execute (unnamed): SELECT postgis_version()
Mapserv.exe is eating now 52% of CPU and nothing else seems to happen.
-Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: thomas bonfort [mailto:thomas.bonfort at gmail.com]
> Lähetetty: 22. syyskuuta 2011 16:47
> Vastaanottaja: Rahkonen Jukka
> Kopio: Andreas Douvalis; mapserver-users at lists.osgeo.org
> Aihe: Re: Σχετ: [mapserver-users] Re: Mapserver 6 WMS /
> PostGIS Problem
> When the request hangs, is it the mapserver process or the postgres
> one that is eating all the cpu cycles ?
> thomas
> 2011/9/22 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> > Hi,
> > I can repeat this problem with Mapserver 6.0.1 on Windows
> Vista 32-bit.  I
> > defined one PostGIS test layer without metadata and
> GetCapabilities fails
> > after a long waiting. With DEBUG 5 the last line in
> MS_ERRORFILE that
> > appears is this
> > msPostGISLayerIsOpen called.
> > Adding "wms_extent" corrects the situation.  Same mapfile
> does work on Linux
> > and it used to work for me on Windows too with Mapserver 5.x.
> > -Jukka Rahkonen-
> > ________________________________
> > Lähettäjä: Andreas Douvalis [mailto:anddreas2 at yahoo.gr]
> > Lähetetty: 22. syyskuuta 2011 10:14
> > Aihe: Σχετ: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
> > No problem with pgsql
> > <!--[if !supportLineBreakNewLine]-->
> > <!--[endif]-->
> > It takes 78 ms the sql of the layer that it doesn't work
> with wms get map
> > request.
> > Unfortunately  there is no debug error to check the query
> that mapserver
> > runs.
> > Απο: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> > Προς: 'anddreas2' <anddreas2 at yahoo.gr>;
> "'mapserver-users at lists.osgeo.org'"
> > <mapserver-users at lists.osgeo.org>
> > Στάλθηκε: 9:32 π.μ. Πέμπτη, 22 Σεπτεμβρίου 2011
> > Θεμα: Re: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
> > Hi,
> > Basically it means that the SQL query for getting the
> extents of your layer
> > is slow.
> > Set timing on with \timing on in your psql window and run query
> > select st_extent(geom) from titles;
> > http://postgis.refractions.net/docs/ST_Extent.html
> > How long does it take? Do vacuum analyze for the table and
> try again to see
> > if there has been some trouble with indexes.
> > Anyway, it is always faster to get extents from the
> metadata line than from
> > PostGIS, but normally it should not take very long. For me
> it takes 1500 ms
> > with a table of 300000 polygons.
> > -Jukka Rahkonen-
> >> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> >> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta anddreas2
> >> Lähetetty: 22. syyskuuta 2011 8:52
> >> Vastaanottaja: mapserver-users at lists.osgeo.org
> >> Aihe: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
> >> I found the solution:
> >> Just set THE wms_extent METADATA in the layer section and it
> >> works.  Without
> >> Layers wms_extent it crashes.
> >> (Jesus, I spent three days of my life for this stupid thing.
> >> I tested with
> >> all versions of postgis (1.5, 1.4) postgresql (8.4,9.0,9.1).
> >> I am think it
> >> is ms4w problem).
> >> View this message in context:
> >> http://osgeo-org.1803224.n2.nabble.com/Mapserver-6-WMS-PostGIS
> >> -Problem-tp6387007p6819004.html
> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
