Re: Σχετ: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
Smith, Michael ERDC-CRREL-NH
Michael.Smith at usace.army.mil
Thu Sep 22 10:06:38 EDT 2011
I have seen similar issues for Oracle, where it queries all geometries and
aggregates the bounds to get an extent. Manually setting the wms_extents
is what we always do.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 9/22/11 9:57 AM, "Rahkonen Jukka" <Jukka.Rahkonen at mmmtike.fi> wrote:
>Hi,
>I turned PostgreSQL statement logging on and I can see this line to
>appear:
>execute (unnamed): SELECT postgis_version()
>Mapserv.exe is eating now 52% of CPU and nothing else seems to happen.
>-Jukka-
>> -----Alkuperäinen viesti-----
>> Lähettäjä: thomas bonfort [mailto:thomas.bonfort at gmail.com]
>> Lähetetty: 22. syyskuuta 2011 16:47
>> Vastaanottaja: Rahkonen Jukka
>> Kopio: Andreas Douvalis; mapserver-users at lists.osgeo.org
>> Aihe: Re: ????: [mapserver-users] Re: Mapserver 6 WMS /
>> PostGIS Problem
>> When the request hangs, is it the mapserver process or the postgres
>> one that is eating all the cpu cycles ?
>> thomas
>> 2011/9/22 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
>> > Hi,
>> > I can repeat this problem with Mapserver 6.0.1 on Windows
>> Vista 32-bit. I
>> > defined one PostGIS test layer without metadata and
>> GetCapabilities fails
>> > after a long waiting. With DEBUG 5 the last line in
>> MS_ERRORFILE that
>> > appears is this
>> > msPostGISLayerIsOpen called.
>> > Adding "wms_extent" corrects the situation. Same mapfile
>> does work on Linux
>> > and it used to work for me on Windows too with Mapserver 5.x.
>> > -Jukka Rahkonen-
>> > ________________________________
>> > Lähettäjä: Andreas Douvalis [mailto:anddreas2 at yahoo.gr]
>> > Lähetetty: 22. syyskuuta 2011 10:14
>> > Aihe: ????: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
>> > No problem with pgsql
>> > <!--[if !supportLineBreakNewLine]-->
>> > <!--[endif]-->
>> > It takes 78 ms the sql of the layer that it doesn't work
>> with wms get map
>> > request.
>> > Unfortunately there is no debug error to check the query
>> that mapserver
>> > runs.
>> > ???: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>> > ????: 'anddreas2' <anddreas2 at yahoo.gr>;
>> "'mapserver-users at lists.osgeo.org'"
>> > <mapserver-users at lists.osgeo.org>
>> > ????????: 9:32 ?.?. ??????, 22 ??????????? 2011
>> > ????: Re: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
>> > Hi,
>> > Basically it means that the SQL query for getting the
>> extents of your layer
>> > is slow.
>> > Set timing on with \timing on in your psql window and run query
>> > select st_extent(geom) from titles;
>> > http://postgis.refractions.net/docs/ST_Extent.html
>> > How long does it take? Do vacuum analyze for the table and
>> try again to see
>> > if there has been some trouble with indexes.
>> > Anyway, it is always faster to get extents from the
>> metadata line than from
>> > PostGIS, but normally it should not take very long. For me
>> it takes 1500 ms
>> > with a table of 300000 polygons.
>> > -Jukka Rahkonen-
>> >> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
>> >> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta anddreas2
>> >> Lähetetty: 22. syyskuuta 2011 8:52
>> >> Vastaanottaja: mapserver-users at lists.osgeo.org
>> >> Aihe: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
>> >> I found the solution:
>> >> Just set THE wms_extent METADATA in the layer section and it
>> >> works. Without
>> >> Layers wms_extent it crashes.
>> >> (Jesus, I spent three days of my life for this stupid thing.
>> >> I tested with
>> >> all versions of postgis (1.5, 1.4) postgresql (8.4,9.0,9.1).
>> >> I am think it
>> >> is ms4w problem).
>> >> View this message in context:
>> >> http://osgeo-org.1803224.n2.nabble.com/Mapserver-6-WMS-PostGIS
>> >> -Problem-tp6387007p6819004.html
>> >> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> mapserver-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
