[mapserver-users] Help!
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Apr 6 16:49:15 EDT 2012
What do you get if you try this url:
http://localhost/cgi-bin/wms?MODE=map&MAP=C:/wwwroot/QGISMap/QGISMap.map&layers=province_dd
-Steve W
On 4/6/2012 4:17 PM, Özgür Arslan wrote:
> Hi All,
> I am new in open layers and I am trying to demonstrate my mapfile with
> Open layers. Can some one helm me about this please? Code lines are below:
> <!-- MapServer Template -->
> <html>
> <head>
> <title>OpenLayers Example</title>
> <script src="http://openlayers.org/api/OpenLayers.js"></script>
> </head>
> <body>
> <div style="width:100%; height:100%" id="map"></div>
> <script defer="defer" type="text/javascript">
> var map = new OpenLayers.Map('map');
> var wms = new OpenLayers.Layer.MapServer( "QGIS-MAP",
> "http://localhost/cgi-bin/wms?MODE=map&MAP=C:/wwwroot/QGISMap/QGISMap.map",
> {layers: 'province_dd'} );
> map.addLayer(wms);
> map.zoomToMaxExtent();
> </script>
> </body>
> </html>
> # Map file created from QGIS project file
> # Edit this file to customize for your map interface
> # (Created with PyQgis MapServer Export plugin)
> MAP
> NAME "QGIS-MAP"
> # Map image size
> SIZE 500 500
> UNITS meters
> STATUS ON
> EXTENT -2400000 -900000 3100000 4000000
> FONTSET "/wwwroot/fonts/fontset.txt"
> SYMBOLSET '../symbols/symbols.sty'
> PROJECTION
> "proj=lcc"
> "ellps=GRS80"
> "lat_0=49"
> "lon_0=-95"
> "lat_1=49"
> "lat_2=77"
> "datum=NAD83"
> "units=m"
> "no_defs <>"
> END
> SYMBOL
> NAME "S3"
> TYPE pixmap
> IMAGE '/wwwroot/symbols/S3.png'
> END # SYMBOL
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 0 0 255
> IMAGEQUALITY 95
> IMAGETYPE png
> CONFIG "CGI_CONTEXT_URL" "1"
> OUTPUTFORMAT
> NAME agg
> DRIVER AGG/PNG
> IMAGEMODE RGB
> END
> QUERYMAP
> STATUS ON
> SIZE 500 500 # sets the map to be queryable
> STYLE HILITE # the selected object is highligthed
> COLOR 0 255 0
> END # End for QueryMap
> SCALEBAR
> STATUS EMBED
> UNITS KILOMETERS
> INTERVALS 3
> TRANSPARENT TRUE
> OUTLINECOLOR 0 0 0
> END # End for scalebar
> # Legend
> LEGEND
> IMAGECOLOR 255 255 255
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> # Web interface definition. Only the template parameter
> # is required to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should
> # write its output.
> IMAGEPATH '/ms4w/tmp/ms_tmp/'
> # Set IMAGEURL to the url that points to IMAGEPATH
> # as defined in your web server configuration
> IMAGEURL '/ms_tmp/'
> HEADER "header.html"
> FOOTER "footer.html"
> EMPTY "/maps/QGISMap/blank.html"
> # WMS server settings
> METADATA
> 'ows_title' 'QGIS-MAP'
> 'ows_onlineresource'
> 'localhost/cgi-bin/mapserv.exe?map=C:/wwwroot/QGISMap/QGISMap.map'
> 'ows_srs' 'EPSG:4326'
> END
> #Scale range at which web interface will operate
> # Template and header/footer settings
> # Only the template parameter is required to display a map. See
> TEMPLATE 'global.html'
> END
> LAYER
> NAME 'province_dd'
> TYPE POLYGON
> DUMP false
> CONNECTION "http://localhost/cgi-bin/wms?"
> CONNECTIONTYPE WMS
> EXTENT -148.317097 42.348600 -55.567680 86.032387
> DATA '../../../wwwroot/Data/province_dd.shp'
> METADATA
> 'wms_onlineresource' 'http://localhost/cgi-bin/mapserv.exe?map=wms.map&'
> "wms_srs" "EPSG:4326"
> "wms_name" "province_dd"
> "wms_server_version" "1.1.1"
> "wms_format" "image/gif"
> #'ows_title' 'province_dd'
> END
> STATUS ON
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'datum=WGS84'
> 'no_defs'
> END
> LABELITEM 'NAME_ENG'
> CLASSITEM 'NAME_ENG'
> CLASS
> NAME "Alberta"
> EXPRESSION "Alberta"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 130 9 169
> END
> END
> CLASS
> NAME "British Columbia"
> EXPRESSION "British Columbia"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 62 106 166
> END
> END
> CLASS
> NAME "Manitoba"
> EXPRESSION "Manitoba"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 176 232 23
> END
> END
> CLASS
> NAME "New Brunswick"
> EXPRESSION "New Brunswick"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 248 188 159
> END
> END
> CLASS
> NAME "Newfoundland"
> EXPRESSION "Newfoundland"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 172 33 56
> END
> END
> CLASS
> NAME "Northwest Territories"
> EXPRESSION "Northwest Territories"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 123 03 213
> END
> END
> CLASS
> NAME "Nova Scotia"
> EXPRESSION "Nova Scotia"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 187 66 185
> END
> END
> CLASS
> NAME "Nunavut"
> EXPRESSION "Nunavut"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 171 222 109
> END
> END
> CLASS
> NAME "Ontario"
> EXPRESSION "Ontario"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 250 20 201
> END
> END
> CLASS
> NAME "Prince Edward Island"
> EXPRESSION "Prince Edward Island"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 69 153 254
> END
> END
> CLASS
> NAME "Quebec"
> EXPRESSION "Quebec"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 6 170 235
> END
> END
> CLASS
> NAME "Saskatchewan"
> EXPRESSION "Saskatchewan"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 251 167 144
> END
> END
> CLASS
> NAME "Yukon Territory"
> EXPRESSION "Yukon Territory"
> STYLE
> WIDTH 0.91
> OUTLINECOLOR 0 0 0
> COLOR 26 34 69
> END
> END
> END
> LAYER
> NAME province_labels
> TYPE ANNOTATION
> STATUS ON
> CLASS
> LABEL
> TYPE truetype
> FONT "calibri"
> SIZE 9
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> POSITION CC
> MINFEATURESIZE 100
> END # End for label
> END # end for class
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> END # End for projection
> END # End for layer
> LAYER
> NAME 'mjrroads'
> TYPE LINE
> DUMP false
> DATA '../../../wwwroot/Data/mjrroads.shp'
> METADATA
> 'ows_title' 'mjrroads'
> END
> STATUS ON
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'datum=WGS84'
> 'no_defs'
> END
> CLASSITEM 'TYPE'
> HEADER "mjrroads_header.html"
> FOOTER "mjrroads_footer.html"
> TOLERANCE 5
> TOLERANCEUNITS PIXELS
> CLASS
> NAME "Primary Highway"
> EXPRESSION "Primary Highway"
> MAXSCALE 2500000
> TEMPLATE "mjrroads_query.html"
> STYLE
> WIDTH 1
> COLOR 0 0 0
> END
> END
> CLASS
> NAME "Expressway"
> EXPRESSION "Expressway"
> STYLE
> WIDTH 2
> COLOR 255 0 0
> END
> END
> END
> LAYER
> NAME major_city_labels
> TYPE ANNOTATION
> STATUS ON
> MAXSCALE 1000000
> DATA '../../../wwwroot/Data/mjcities'
> LABELITEM 'NAME'
> CLASS
> LABEL
> TYPE truetype
> FONT "calibri"
> SIZE 8
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> POSITION CC
> MINFEATURESIZE 100
> END # End for label
> END # end for class
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> END # End for layer
> LAYER
> NAME 'mjcities'
> TYPE POINT
> DUMP false
> DATA '../../../wwwroot/Data/mjcities.shp'
> METADATA
> 'ows_title' 'mjcities'
> END
> STATUS ON
> MAXSCALE 2500000
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'datum=WGS84'
> 'no_defs'
> END
> CLASS
> NAME 'mjcities'
> STYLE
> SYMBOL "S3"
> SIZE 17
> OUTLINECOLOR 0 0 0
> COLOR 0 0 255
> END
> END
> END
> END
> mapserver-users at lists.osgeo.org
