[mapserver-users] Help!
Özgür Arslan
ozgurarslan81 at hotmail.com
Fri Apr 6 16:17:07 EDT 2012
Hi All,
I am new in open layers and I am trying to demonstrate my mapfile with Open layers. Can some one helm me about this please? Code lines are below:
<!-- MapServer Template -->
<html>
<head>
<title>OpenLayers Example</title>
<script src="http://openlayers.org/api/OpenLayers.js"></script>
</head>
<body>
<div style="width:100%; height:100%" id="map"></div>
<script defer="defer" type="text/javascript">
var map = new OpenLayers.Map('map');
var wms = new OpenLayers.Layer.MapServer( "QGIS-MAP",
"http://localhost/cgi-bin/wms?MODE=map&MAP=C:/wwwroot/QGISMap/QGISMap.map", {layers: 'province_dd'} );
map.addLayer(wms);
map.zoomToMaxExtent();
</script>
</body>
</html>
# Map file created from QGIS project file
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME "QGIS-MAP"
# Map image size
SIZE 500 500
UNITS meters
STATUS ON
EXTENT -2400000 -900000 3100000 4000000
FONTSET "/wwwroot/fonts/fontset.txt"
SYMBOLSET '../symbols/symbols.sty'
PROJECTION
"proj=lcc"
"ellps=GRS80"
"lat_0=49"
"lon_0=-95"
"lat_1=49"
"lat_2=77"
"datum=NAD83"
"units=m"
"no_defs <>"
END
SYMBOL
NAME "S3"
TYPE pixmap
IMAGE '/wwwroot/symbols/S3.png'
END # SYMBOL
# Background color for the map canvas -- change as desired
IMAGECOLOR 0 0 255
IMAGEQUALITY 95
IMAGETYPE png
CONFIG "CGI_CONTEXT_URL" "1"
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
QUERYMAP
STATUS ON
SIZE 500 500 # sets the map to be queryable
STYLE HILITE # the selected object is highligthed
COLOR 0 255 0
END # End for QueryMap
SCALEBAR
STATUS EMBED
UNITS KILOMETERS
INTERVALS 3
TRANSPARENT TRUE
OUTLINECOLOR 0 0 0
END # End for scalebar
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/ms4w/tmp/ms_tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/ms_tmp/'
HEADER "header.html"
FOOTER "footer.html"
EMPTY "/maps/QGISMap/blank.html"
# WMS server settings
METADATA
'ows_title' 'QGIS-MAP'
'ows_onlineresource' 'localhost/cgi-bin/mapserv.exe?map=C:/wwwroot/QGISMap/QGISMap.map'
'ows_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
TEMPLATE 'global.html'
END
LAYER
NAME 'province_dd'
TYPE POLYGON
DUMP false
CONNECTION "http://localhost/cgi-bin/wms?"
CONNECTIONTYPE WMS
EXTENT -148.317097 42.348600 -55.567680 86.032387
DATA '../../../wwwroot/Data/province_dd.shp'
METADATA
'wms_onlineresource' 'http://localhost/cgi-bin/mapserv.exe?map=wms.map&'
"wms_srs" "EPSG:4326"
"wms_name" "province_dd"
"wms_server_version" "1.1.1"
"wms_format" "image/gif"
#'ows_title' 'province_dd'
END
STATUS ON
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
LABELITEM 'NAME_ENG'
CLASSITEM 'NAME_ENG'
CLASS
NAME "Alberta"
EXPRESSION "Alberta"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 130 9 169
END
END
CLASS
NAME "British Columbia"
EXPRESSION "British Columbia"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 62 106 166
END
END
CLASS
NAME "Manitoba"
EXPRESSION "Manitoba"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 176 232 23
END
END
CLASS
NAME "New Brunswick"
EXPRESSION "New Brunswick"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 248 188 159
END
END
CLASS
NAME "Newfoundland"
EXPRESSION "Newfoundland"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 172 33 56
END
END
CLASS
NAME "Northwest Territories"
EXPRESSION "Northwest Territories"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 123 03 213
END
END
CLASS
NAME "Nova Scotia"
EXPRESSION "Nova Scotia"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 187 66 185
END
END
CLASS
NAME "Nunavut"
EXPRESSION "Nunavut"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 171 222 109
END
END
CLASS
NAME "Ontario"
EXPRESSION "Ontario"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 250 20 201
END
END
CLASS
NAME "Prince Edward Island"
EXPRESSION "Prince Edward Island"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 69 153 254
END
END
CLASS
NAME "Quebec"
EXPRESSION "Quebec"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 6 170 235
END
END
CLASS
NAME "Saskatchewan"
EXPRESSION "Saskatchewan"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 251 167 144
END
END
CLASS
NAME "Yukon Territory"
EXPRESSION "Yukon Territory"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 26 34 69
END
END
END
LAYER
NAME province_labels
TYPE ANNOTATION
STATUS ON
CLASS
LABEL
TYPE truetype
FONT "calibri"
SIZE 9
COLOR 255 255 255
OUTLINECOLOR 0 0 0
POSITION CC
MINFEATURESIZE 100
END # End for label
END # end for class
PROJECTION
"proj=latlong"
"ellps=WGS84"
END # End for projection
END # End for layer
LAYER
NAME 'mjrroads'
TYPE LINE
DUMP false
DATA '../../../wwwroot/Data/mjrroads.shp'
METADATA
'ows_title' 'mjrroads'
END
STATUS ON
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASSITEM 'TYPE'
HEADER "mjrroads_header.html"
FOOTER "mjrroads_footer.html"
TOLERANCE 5
TOLERANCEUNITS PIXELS
CLASS
NAME "Primary Highway"
EXPRESSION "Primary Highway"
MAXSCALE 2500000
TEMPLATE "mjrroads_query.html"
STYLE
WIDTH 1
COLOR 0 0 0
END
END
CLASS
NAME "Expressway"
EXPRESSION "Expressway"
STYLE
WIDTH 2
COLOR 255 0 0
END
END
END
LAYER
NAME major_city_labels
TYPE ANNOTATION
STATUS ON
MAXSCALE 1000000
DATA '../../../wwwroot/Data/mjcities'
LABELITEM 'NAME'
CLASS
LABEL
TYPE truetype
FONT "calibri"
SIZE 8
COLOR 0 0 0
OUTLINECOLOR 255 255 255
POSITION CC
MINFEATURESIZE 100
END # End for label
END # end for class
PROJECTION
"proj=latlong"
"ellps=WGS84"
END # End for layer
LAYER
NAME 'mjcities'
TYPE POINT
DUMP false
DATA '../../../wwwroot/Data/mjcities.shp'
METADATA
'ows_title' 'mjcities'
END
STATUS ON
MAXSCALE 2500000
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'mjcities'
STYLE
SYMBOL "S3"
SIZE 17
OUTLINECOLOR 0 0 0
COLOR 0 0 255
END
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120406/3ebac501/attachment-0001.html
